2001 Dodge Intrepid Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2814
Printed Date: May 12, 2026 at 3:07 PM
Topic: 2001 Dodge Intrepid Alarm/Remote Start Wiring
Posted By: bopierce
Subject: 2001 Dodge Intrepid Alarm/Remote Start Wiring
Date Posted: August 15, 2002 at 5:44 PM
I am trying to install a keyless entry. Does anybody have a wire diagram for a 2001 intrepid.
Thnx
Posted By: Velocity Motors
Date Posted: August 16, 2002 at 12:31 AM
|              12V|pink/black or red   |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue/white      |+  |ignition harness            |
|  SECOND IGNITION|GREEN/ red           |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|WHITE/ green         |*1 |back of fusebox             |
|     POWER UNLOCK|same wire           |*1 |                            |
|       LOCK MOTOR|orange              |   |BCM *2                      |
|     UNLOCK MOTOR|dk. blue            |   |BCM *2                      |
|    DISARM DEFEAT|pink/black          |   |BCM *2                      |
| PARKING LIGHTS +|do not use          |   |                            |
| PARKING LIGHTS -|yellow *3           |   |headlight switch            |
|       HEADLIGHTS|pur & pur/red or *3 |+  |fuse relay box (low only)   |
|     DOOR TRIGGER|yellow              |-  |*4                          |
|  TRUNK/HATCH PIN|tan/black           |-  |drivers kick panel          |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |at release switch           |
|  FCTRY ALARM ARM|lt. GREEN/ orange    |*6 |drivers kick panel          |
|FCTRY ALRM DISARM|same wire           |   |                            |
|       TACHOMETER|*5                  |   |one of the coils            |
|       BRAKE WIRE|WHITE/ tan           |+  |at brake switch             |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|  LF WINDOW UP/DN|lt. blue - white    |A  |at drivers door motor       |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|blu/wht - RED / blu   |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|gry/blk - grn/wht   |A  |in drivers door or dkp      |
Notes:
NOTE:  Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting.  *1 Locks are positive trigger through resistors.  Use 2.7K (2700) ohms for lock and 620 ohms for unlock.  *2 BCM is located on the left side of dash with junction block  *3 Use a 110 ohm resistor to ground (-) for parking lights and a 220 ohm resistor to ground (-) will do both headlights and parking lights.  *4 In a brown connector at the rear of the fuse box.  *5 This vehicle has an ignition coil for each cylinder.  For tach use a tan/stripe wire at any one of the coils.  *6 Arm is positive trigger thru a 1.87K ohm resistor, this will also lock the doors. Disarm is positive trigger thru a 680 ohm resistor, if use double pulse this will also unlock the doors. Must use relays.
Posted By: bopierce
Date Posted: August 16, 2002 at 5:32 AM
Thnx Jeff
this will help
Date Posted: August 16, 2002 at 7:56 AM
No problemo
