Need help on 1992 Honda Accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28284
Printed Date: May 14, 2026 at 2:09 PM
Topic: Need help on 1992 Honda Accord
Posted By: D2005L
Subject: Need help on 1992 Honda Accord
Date Posted: March 13, 2004 at 12:08 AM
Need help on installing a Phoenix Digital alarm with remote start.
Posted By: boomer_106
Date Posted: March 15, 2004 at 11:00 AM
Remote Starter Wiring Colors and Notes | Function | | Vehicle Color | Location | Start: | | BLACK/ WHITE | IGNITION SWITCH HARNESS | Ignition #1: | | BLACK / YELLOW | IGNITION SWITCH HARNESS | Ignition #2: | | YELLOW | IGNITION SWITCH HARNESS (HEATER) | Ignition #3: | | N/A | | Accessory: | | WHITE/ BLACK | IGNITION SWITCH HARNESS | Brake Light: | | GREEN / WHITE (+) | AT SWITCH,BRACKET ABOVE PEDAL BRACKET | Tach Signal: | | BLUE | AT DISTRIBUTOR OR DASH FUSE BLOCK | Parking Lights: | | BLACK/ RED (+) | HEADLIGHT SWITCH OR AT FUSE BOX | Headlights: | | BLUE/RED | (-) AT HEADLIGHT SWITCH | OEM Alarm Disarm: | | BLUE OR BLUE/WHITE | (-) AT DIS-ARM SWITCH | OEM Alarm Arm: | | N/A | | Diesel Glow Plug: | | | | Clutch Bypass Wire: | | | | Notes: | | |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | Vehicle Color | Location | Constant +12 Volts: | | WHITE | IGNITION SWITCH HARNESS | Starter Kill: | | BLACK/ WHITE | IGNITION SWITCH HARNESS | Ignition +12 Volts: | | BLACK / YELLOW | IGNITION SWITCH HARNESS | Dome Lights/Superv: | | BLACK/ WHITE (-) | BROWN CONNECTOR ABOVE FUSE PANEL | OEM Horn: | | BLUE/RED OR GRAY | (-) STEERING COLUMN HARNESS | Power Lock: | | BLACK/ WHITE | DRIVER KICK PANEL, 2 PIN PLUG TAPPED | Power Unlock: | | BLACK/ RED | TO HARNNESS ABOVE FUSE BOX * | Trunk Release: | | N/A | | Alarm Input Wire: | | BLACK/ WHITE (-) | BROWN CONNECTOR ABOVE FUSE PANEL | Notes: | | * See Note #201 - Negative Pulse Door Lock Diagram. |
