94 Honda Civic, One wire left
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3101
Printed Date: May 13, 2026 at 11:08 AM
Topic: 94 Honda Civic, One wire left
Posted By: 94civic
Subject: 94 Honda Civic, One wire left
Date Posted: August 27, 2002 at 2:31 AM
I have a factory installed alarm in my 94 civic.  I bought one of those Pager alarms that connect to an existing alarm system, and connected it up with the factory system (door triggers, etc)   EXCEPT for the most important wire.  I cant find the wire that Grounds when the alarm is engaged.  If you dont get what im saying.....I need to know which wire (Where more like it) I can tap into so that the pager moduel knows when to shut on and off.
I tested all the wires coming out of the back of the factory moduel, but none of them ground when I activate the factory alarm.  I could easily ground the pager to the car, but have the pager go crazy everytime i get into my car is dumb.     Is the wire im looking for hidden somewhere? Any help would rock.
Posted By: cpgoose
Date Posted: September 06, 2002 at 9:15 AM
Hmmm, I've heard the alarms and stereos in civics are tricky.  When you pull out the stereo, isn't the alarm on top of it? (built-in so to speak)?  I wonder if the shut-down wire you're looking for could be built into the stereo's wiring?
Someone can probably add to this.
Posted By: the12volt
Date Posted: September 06, 2002 at 10:49 AM
How does your factory alarm arm and disarm? With a key? A remote? If by remote, does it have keyless entry?
