1999-2004 Volvo C70 Conv Stereo Wires?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32678
Printed Date: May 05, 2026 at 5:00 PM
Topic: 1999-2004 Volvo C70 Conv Stereo Wires?
Posted By: GalpinAudio
Subject: 1999-2004 Volvo C70 Conv Stereo Wires?
Date Posted: May 24, 2004 at 6:19 PM
I've got a 2004 Volvo C70 which I'm going to attempt installing a Pioneer Avic-N1 all in one am/fm/cd/dvd/navigation unit in.  I know this vehicle has not changed since 1999, and I know it has dolby surround w/center channel and a factory amplifier.  Has anyone done an aftermarket unit in one of these yet and if so any info such as wire colors, adapters, bypasses, etc would be greatly appreciated.  I called Metra and they were no help.
Thanks,
Matthew
Never Let Those Who Say It Cant Be Done Stand In The Way While You Do It!
Posted By: jfk51502003
Date Posted: May 28, 2004 at 4:17 PM
DIRECTWIRE™ WIRING INFORMATION - VOLVO / C70 / 2003 / Audio
[PRINT THIS PAGE]
Radio 12vRED / black + radio harness
Radio Groundblack - radio harness
Radio Ignitionyellow/purple + radio harness
Radio Illumination
Factory Amp Turn-on
Power Antennablue/white or blue / YELLOW + radio harness
LF Speaker +/-
RF Speaker +/-
LR Speaker +/-
RR Speaker +/-
posted_image
Immobilizer Bypass Module:Required: YesType: TransponderPart #: 555U
Notes: N/A
posted_image
DIRECTWIRE™ WIRING INFORMATION - VOLVO / C70 / 2003 / Remote Start
[PRINT THIS PAGE]
12voltsred (10A) + ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12V.
Starteryellow/white + ignition harness
Second Starter
IgnitionGREEN/ YELLOW + ignition harness
Second Ignitionblue / YELLOW + ignition harness
Third Ignition
Accessoryyellow/purple 5wiignition harness
Second Accessory
Keysenseyellow (required) + ignition harness
Power Lockyellow/gray - keyless module
Notes: The keyless entry module is located above the hood release. It is a black box with 2 green plugs.
Power Unlockgray/red - keyless module
Requires a double pulse for unlock.
Lock Motoryellow 5widriver kick, door harness
Unlock Motorblue/brown 5widriver kick, door harness
Parking Lights+white + headlight switch
Notes: If the vehicle has factory daytime running lights, and you use the white at the switch for parking lights, the headlights will flash as well. The solution is to wire it as a 5 wire system. Also, there are two white wires at the switch. They go to the same pin. Treat them like one wire.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Triggerpink/black - keyless module
To avoid the dome light delay, there are 2 separate door trigger wires at the keyless module. They are: LF WHITE/ black, RF yellow/brown. Both wires are negative trigger and must be diode isolated from each other.
Dome Supervisioncomes on with unlock
Trunk/Hatch Pinblue/brown - keyless module
Hood Pinyellow/black - keyless module
Trunk/Hatch Releaseyellow/white - keyless module
Power Sliding Door
Factory Alarm Armarms with lock
Factory Alarm Disarmdisarms with unlock
Disarm No Unlocksingle pulse unlock wire
TachometerNOT red, black, or yellow ac any ignition coil
Wait to start
Brake Wireyellow + brake pedal switch
Parking Brake
Horn Triggeryellow/red - keyless module
This triggers the alarm horn, the vehicle horns only work with the ignition on.
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Notes: N/A
Date Posted: June 02, 2004 at 9:58 AM
Thanks for the direct info, but unfortunately all it tells is constant, acc, and ant.  My partner and I got the rest figured out though.
For anyone out there in need of the info it is as follows:
12V constant - RED / Black
12V acc - Yellow/Violet
Ground - Black
Power Ant - Blue / YELLOW
VSS - Yellow/Black
Center Channel  + Pos - Blue/White
Center Channel - Neg - Blue/Black
There is a factory amplifier in the trunck on the drivers side.  There are 3 din cables going to the back of the radio.  One is the CD Changer, one is the dolby processor, and one is the Amp.  You will need to use the din cable that goes to the amp.  Figure out which one it is and cut it behind the radio.  You will need 4 RCA ends to solder onto the cut din plug.
The wire colors are as follows:
Blue - Not Used
Grey - Remote turn on
Purple - Right Rear +
Green - Left Rear +
Red - Right Front +
White - Left Front +
The shields are the grounds and must all be combined together as common ground system.
Hope this helps anyone else out there who gets one of these beasts.
Good Luck
