2000 Celica ignition wiring diagram?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33521
Printed Date: April 20, 2026 at 4:41 AM
Topic: 2000 Celica ignition wiring diagram?
Posted By: cheechandchong
Subject: 2000 Celica ignition wiring diagram?
Date Posted: June 08, 2004 at 2:14 PM
i have been looking for the ignition wiring diagram for the 2000+ celica..plz help
Posted By: boomer_106
Date Posted: June 10, 2004 at 11:26 AM
It would help if you stated what  you were trying to do but, maybe this is what you  seek.
Toyota
Celica
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWTICH HARNESS
Ignition  #1:
BLACK/ ORANGE
IGNITION SWITCH HARNESS
Ignition #2:
BLUE/RED
Ignition  #3:
N/A
Accessory:
GRAY
Brake  Light:
GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BROWN / WHITE
AT ECM NEAR BATTERY
Parking Lights:
GREEN (+)
# PIN CONNECTOR ON BACK OF FUSE PANEL
Headlights:
OEM Alarm  Disarm:
DISARMS WITH UNLOCK
OEM Alarm  Arm:
ARMS WITH LOCK
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
Toyota
Celica
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE & BLACK/ RED
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK/ ORANGE
Dome  Lights/Superv:
RED / WHITE (-)
AT BCM
OEM Horn:
BLUE/BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
VIOLET/WHITE
AT SWITCH IN CENTER CONSOLE *
Power  Unlock:
PINK/BLACK
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE (-)
AT BCM
Notes:
* Child Safety Locks: GREEN (-) In Same Conn. As Door Lock Wires Above. See Note # 209 - Child Safety Door Lock Diagram.
