1980 cutlass olds wiring colors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34342
Printed Date: April 21, 2026 at 6:47 AM
Topic: 1980 cutlass olds wiring colors
Posted By: powerhx2
Subject: 1980 cutlass olds wiring colors
Date Posted: June 22, 2004 at 2:04 AM
hi, i am looking for the color code for my cutlass so that i can install an alarm and i wanted to also add power locks to the front dors.......... Thanks for any help
kvt-911dvd
2 Autotek Stealth xs.1500's
2 yellow top
2 MTX 3'' 2 ways
2 6x9 alpine type r's
2 15's poweramper xp^2
alpine mrv-f407 4 channel
150 amp anl fuse
Posted By: boomer_106
Date Posted: June 22, 2004 at 10:22 AM
The oldest I can find is 81-87.   You MIGHT be able to use it as a guide. On the other hand it may do you absolutely no good. You MUST verify with your meter before making connections. Good luck to ya
Oldsmobile
Cutlass (RWD)
1981-1987
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
PURPLE OR YELLOW
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
ORANGE
Ignition  #3:
N/A
Accessory:
BROWN
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT COIL *
Parking Lights:
BROWN
(+) AT LIGHT SWITCH
Headlights:
YELLOW
(+) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Carburated Engine. ** See Note #300 - GM Rear Wheel Drive Vehicles.
Oldsmobile
Cutlass (RWD)
1981-1987
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED AND RED
Starter  Kill:
PURPLE OR YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
WHITE
(-) AT PIN SWITCH OR COURTESY LIGHT
OEM Horn:
BLACK
(-) STEERING COLUMN HARNESS
Power  Lock:
LIGHT BLUE
DRIVER'S KICK PANEL ***
Power  Unlock:
BLACK
Trunk  Release:
BLACK
(+) AT RELEASE SWITCH
Alarm  Input Wire:
WHITE
Notes:
** See Note #202 - Positive Pulse Door Lock Diagram.
Posted By: powerhx2
Date Posted: June 22, 2004 at 5:29 PM
Thanks for the wire colors..............i was also wondering how i would install power lock actuators,
they are 2 wire actuators.......and i want to hook them up with my alarm and have a switch to work
them even when i am not arming the car,,,,if posible , show how i would hook up the relays so it would mke it easy for me to install,,,, i   have the viper 790xv responder.
       ........................Thanks for the help
kvt-911dvd
2 yellow top
2 MTX 3'' 2 ways
150 amp anl fuse
