Nissan Quest 2001
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3559
Printed Date: May 03, 2026 at 2:17 PM
Topic: Nissan Quest 2001
Posted By: Ohmz
Subject: Nissan Quest 2001
Date Posted: September 12, 2002 at 5:48 AM
Hello, I need the wiring diagram for a 2001 Nissan Quest. I'm installing an alarm/remote start. I need to also know if there is any special modules I need to use for the remote start or door locks. Thank you!posted_image
My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
Posted By: the12volt
Date Posted: September 12, 2002 at 10:46 AM
Here's what I have for a 2001 Nissan Quest:
FACTORY KEYLESS SYSTEM  " Right side of steering wheel, high in dash "
FACTORY SECURITY SYSTEM  " Right side of steering wheel, high in dash "
BCM LOCATION     G.E.M.   Behind glove box or right side of dash
DOOR TRIGGERS
LF LATCH SWITCH  Red   At smart entrance   -
RF LATCH SWITCH  RED / white   At smart entrance   -
LR LATCH SWITCH  RED / green   At smart entrance   -
RR LATCH SWITCH  RED / green   At smart entrance   -
TRUNK TRIGGER  RED / white   At smart entrance   -
+12 V DC START OR CRANK  Red   Ignition harness   +
+12 V DC ACCESSORY  WHITE/ green   Ignition harness   +
+12 V DC IGN.1  BLACK/ red   Ignition harness   +
+12 V DC IGN.2  RED / green   Ignition harness   +
+12 V DC BATTERY 1  WHITE/ violet   Ignition harness   +
HIGH CURRENT PARKING LTS  Pink/blue   Driver's kick   +
LF BULB  Pink/blue   At bulb   +
RF BULB  Pink/blue   At bulb   +
LR BULB  Pink/blue   At bulb   +
RR BULB  Pink/blue   At bulb   +
DOOR LOCK CIRCUIT TYPE   3 wire   -
DOOR LOCK  GREEN / WHITE   At smarts module   -
DOOR UNLOCK  GREEN/ orange   At smarts module   -
FACTORY SECURITY ARM  Red   At smarts module   -
FACTORY SECURITY DISARM  RED / black   At smarts module   -
DRIVER'S DOOR LOCK MOTOR  GREEN/ YELLOW   At smarts module   +
DRIVER'S DOOR UNLOCK MTR  WHITE/ green   At smarts module   +
PASS DOOR LOCK MOTOR  GREEN/ YELLOW   At smarts module   +
PASS DOOR UNLOCK MOTOR  WHITE/ red   At smarts module   +
TACH REFERENCE white Pin 3 at PCM
CRNKSHFT POSITION SENSOR  Lt. Brown  " Pin 97, PCM "
CAMSHAFT POSITION SENSOR  Orange   At Pin 49 of PCM
FUEL INJECTOR  GREEN/ orange   At pin 102 of PCM
BRAKE SWITCH  Yellow/black   At switch   +
REVERSE LIGHTS  Blue/red   At switch   +
HORN SWITCH  Sky blue/black   At horn relay   -
HAZARD LIGHT CIRCUIT TYPE   4 way
LEFT FRONT HAZARD  RED / green   At hazard switch   +
RIGHT FRONT HAZARD  RED / green   At hazard switch   +
LEFT REAR HAZARD  RED / brown   At hazard switch   +
RIGHT REAR HAZARD  RED / white   At hazard switch   +
HEADLIGHTS  Yellow   At lighting switch   -
HIGH BEAM SENSE  Lt. GREEN/ red   Combination switch   -
DRIVER'S WINDOW UP  Purple   Driver's door switch   +
DRIVER'S WINDOW DOWN  Blue/red   Driver's door switch   +
R.F. WINDOW UP  Blue / YELLOW   Passenger door switch   +
R.F. WINDOW DOWN  Blue/orange   Passenger door switch   +
POWER SUNROOF OPEN  BLACK/ red   At sunroof switch   -
POWER SUNROOF CLOSED  WHITE/ blue   At sunroof switch   -
VSS SPEED SENSOR  GREEN/ YELLOW   Pin 29 at PCM
