1999 GMC Yukon Tip
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=394
Printed Date: April 19, 2026 at 7:31 AM
Topic: 1999 GMC Yukon Tip
Posted By: Velocity Motors
Subject: 1999 GMC Yukon Tip
Date Posted: April 20, 2002 at 3:12 PM
There are several unused plugs along side the firewall ( small black discs ) and if you pop them out with a screw driver you can drill a small hole and then run your power cable from the new amp to the battery. I don't suggest trying to tap into any of the vehciles factory power wire that are used for soemthing else because of the high current draw from the amplifier will probably blow fuses all the time.
