2004 Dodge Ram 3500 Radio Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40007
Printed Date: April 18, 2026 at 8:44 AM
Topic: 2004 Dodge Ram 3500 Radio Wiring
Posted By: mdlnor
Subject: 2004 Dodge Ram 3500 Radio Wiring
Date Posted: September 29, 2004 at 6:03 PM
Can anyone give the wiring diagram for the radio connector for the 2004 dodge ram, It is not the infinity radio just the regular 4 speaker system.
Posted By: Teken
Date Posted: September 29, 2004 at 6:29 PM
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 2004 / Audio
Radio 12v gray/red + radio harness
Radio Ground black & BLACK/ lt. green - radio harness
Radio Ignition pink / YELLOW + radio harness
Radio Illumination ORANGE / tan (dimmer) + radio harness
Factory Amp Turn-on dk. green + radio harness
Power Antenna N/A
LF Speaker +/- GREEN/ YELLOW - GREEN/ lt. blue +,- radio harness or amplifier
Notes: The amplifier is behind the glove box.
RF Speaker +/- gray / YELLOW - gray/lt. blue +,- radio harness or amplifier
LR Speaker +/- gray/lt. green - gray/green +,- radio harness or amplifier
RR Speaker +/- GREEN/ lt. green - GREEN/ gray +,- radio harness or amplifier
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
Please let me know if this is the correct vehicle. If not I will repost the information.
Regards
EVIL Teken . . .
Posted By: mdlnor
Date Posted: September 29, 2004 at 6:37 PM
Awesome!!!!!!!!, Now I can install my system, I will check it with the wires in back of the radio. It looks like the correct 1. thank you
Posted By: swamprat323
Date Posted: September 29, 2004 at 8:06 PM
Get a harness, dont cut it off and then tie into the wires, harness also saves time.
Posted By: mdlnor
Date Posted: September 30, 2004 at 10:01 PM
I am just adding a line converter so I can run RCAs to my eq, then to my amps
Posted By: monster57
Date Posted: November 29, 2004 at 10:33 AM
i didnt see the factory amp behind the glove box
