04 Scion xB, Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40192
Printed Date: April 19, 2026 at 10:26 AM
Topic: 04 Scion xB, Alarm/Remote Start Wiring
Posted By: shesaidshewas18
Subject: 04 Scion xB, Alarm/Remote Start Wiring
Date Posted: October 03, 2004 at 7:34 AM
I did a search, and for all the wiring diagrams for the Scion, it says to meter the stated wires while the key was in the hole. Im just wondering why do you meter the wires for? Dont you just hook up the (-) lock/unlock wires from the alarm to the corresponding wires to the Scion?
Posted By: swamprat323
Date Posted: October 03, 2004 at 8:02 AM
the wire guide may be wrong, i have seen it severl times, you are just doulb checking it.
Posted By: mo12v
Date Posted: October 03, 2004 at 9:19 AM
This is what I used:
Constant 12 voltsWHITE/ BLUE ,WHITE/ REDIGNITION SWITCH HARNESS
Ignition 12 voltsBLACKIGNITION SWITCH HARNESS
StarterBLACKIGNITION SWITCH HARNESS
Dome LightRED (DR),RED / WHITE(PS)13 PIN CONN ON BACK OF FUSE BOX *
Trunk Pin SwitchRED / WHITE (-)SAME AS ABOVE
Parking LampGREEN/ BLACK (DR) (+)13 PIN CONN ON FRONT OF FUSE BOX **
Power LockBROWN / YELLOW14 PIN CONN IN DRIVER KICK PANEL
Power UnlockGREEN/ BLACK14 PIN CONN IN DRIVER KICK PANEL ***
* Both Wires Are (-) Trigger Must Diode Isolate, Stripe Towards Factory Wire. **Passenger Side Parking Lights-GREEN YELLOW (+) In Same Connector. ***Using YELLOW/BLACK (-) In Same Conn Will Give You Driver Door Priority. First Pulse-Driver Door, Second Pulse All Doors. This Is Key Cylinder Wire. Child Safety Door Lock Circuit
Child Safety Wire Is BLUE/RED In Same Conn As Door Lock Wires.
Accessories
Window UpD\ RED / BLU P\ RED / BLU D\ RED / YEL P\ RED / BLK @ MAIN SWITCH
Window DownF/ GRN/WHT F/ GRN/WHT R/ GRN/YEL R/ GRN/BLK
Ign Key WarnYELLOW (-)STEERING COLUMN HARNESS
Trunk ReleaseNONE
OEM HornWHITE/ RED (-)STEERING COLUMN HARNESS *
HeadlightsBLACK/ WHITE (-)AT HEAD LIGHT SWITCH OR COLUMN HARN.
OEM Alarm ArmNONE
OEM Alarm DisarmNONE
*Also Found At Door Lock Control Relay Behind Driver Dash, Right Of Column #211 See Reversal Rest At Ground Power Window Circuit Diagram Under Hood Pin - None Under Hood Horn- GREEN/ RED (+) At OEM Horn Behind Driver Side Grill
Remote Start
Tach SignalBLACKAT ECM BEHIND PASS DASH NEAR GLOVEBOX
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS
Ignition #3NONE
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNON GROUNDING TYPE
Brake LightGREEN/ RED (+)AT SWITCH ABOVE BRAKE PEDAL **
Reverse LightRED / BLACK (+)9 PIN CONNECTOR ON FRONT OF FUSE BOX
Rear Window DefrostRED / BLACK (+)AT DEFOGGER RELAY BY FUSE/RELAY BOX
* Tach Can Also Be Obtained At Any Coil, GREEN/ ? Wire. ** Brake Switch Wire Also Found In 13 Pin Conn On Front Of Fuse Box Beside Parking Light Wires.
MO
Date Posted: October 04, 2004 at 10:59 PM
