1999 mitsu eclipse
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40348
Printed Date: April 19, 2026 at 8:42 PM
Topic: 1999 mitsu eclipse
Posted By: xavierny25
Subject: 1999 mitsu eclipse
Date Posted: October 05, 2004 at 8:04 PM
          i plan on installing a new alarm system in my eclipse and need some help with locating the wires i need for the install.or just the color codes would be good thanx for ur help guys
        thanx  xavierny25
Posted By: mo12v
Date Posted: October 05, 2004 at 8:29 PM
This is what I have:
Constant 12 voltsWHITE/ YELLOWIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ WHITEIGNITION SWITCH HARNESS
StarterBLACK/ REDIGNITION SWITCH HARNESS
Dome LightRED / GREEN (-)EITHER PIN SWITCH OR COURTESY LIGHT
Trunk Pin SwitchRED / GREEN/ SILVER DOTS(-) BELOW DRIVER STEP PLATE *
Parking LampGREEN / WHITE (+)AT JUNCTION BLOCK IN DR.KICK PLATE **
Power LockBROWN / WHITEAT RELAYS BEHIND PASSENGER **
Power UnlockBROWNSIDE OF CONSOLE ***
* Two RED / GREEN (-) Wires Present, Meter To Find Right One. ** Also Found Under Driver Step Plate In Rear Body Harness *** Door Lock Control Unit Located In Passenger Kick Panel. Relays Located In Console Accessed By Removing 2 Screws. Then Removing Entire Passenger Side Console Panel.With OEM Keyless.  **Negative Pulse Door Locks
Accessories
Window UpD\ GRN/RED P\ BRN/YEL @ MAIN SWITCH
Window DownR/ GRN/BLK S/ GRN/YEL
Ign Key WarnGREEN/ YEL (-) STEERINGCOLUMN HARNESS-GROUNDED WITH KEY OUT
Trunk ReleaseN/A
OEM HornGREEN/ RED (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsRED(-) AT HEADLIGHT SWITCH OR RELAY
OEM Alarm ArmRED / BLUE (-)IN LOOM BEHIND GLOVE BOX
OEM Alarm DisarmBROWN / RED (-)IN LOOM BEHIND GLOVE BOX
 Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalWHITEPIN 58 AT ENGINE CONTROL MODULE *
Ignition #2BLUE/BLACKIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLUEIGNITION SWITCH HARNESS
Neutral SafetyBLACK / YELLOWSWITCH ON DRIVER FRONT OF TRANSAXLE
Brake LightGREEN (+)(+) AT SWITCH ABOVE BRAKE PEDAL
Reverse LightRED / BLUE (+)SWITCH ON TRANSAXLE OR @ JUNCTION BOX
Rear Window DefrostBLUE/RED (-)AT DEFOGGER SWITCH
* Engine Control Module (ECM) Located On Driver Wheelwell. WHITE Tach Wire Is Also Located At Pin #6 In A White 18 Pin Connector Behind Driver Side Of Console.
MO
