2003 Cavalier Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40581
Printed Date: April 20, 2026 at 2:11 PM
Topic: 2003 Cavalier Alarm/Remote Start Wiring
Posted By: haleyhosting
Subject: 2003 Cavalier Alarm/Remote Start Wiring
Date Posted: October 09, 2004 at 5:35 PM
hello i need a wiring diagram. im installing a remote start in a 2003 chevy cavalier. im installing  a python 450esp. also can anyone tell me where to find the Ignition Switch Harness PCM and Cluster
Posted By: Teken
Date Posted: October 09, 2004 at 8:07 PM
Chevrolet Cavalier 2003
Remote start / Security / GPS
Wire/Function Colour Location/Description Polarity
PASSIVE ANTI-THEFT YES PASSLOCK 2 SEE NOTES
12 VOLTS Red Ignition harness +
IGNITION Pink Ignition harness +
ACCESSORY Orange Ignition harness +
ACCESSORY 2 Brown***** Ignition harness +
STARTER Yellow Ignition harness +
TACH White See notes* AC
FUEL INJECTOR Opposite from Pink At any injector on engine AC
LOCK Lt.blue Pin-A4 on Violet plug at BCM** +
UNLOCK White Pin-A3 on Violet plug at BCM** +
DRIVER LOCK MOTOR Gray In driver's kickpanel +
DRIVER UNLOCK MOTOR Tan In driver's kickpanel +
PASSENGER UNLOCK MOTOR White In driver's kickpanel +
DOORPIN SEE NOTES***
TRUNK PIN ORANGE / black Pin-A4 on Lt.blue plug at BCM** -
TRUNK RELEASE BLACK/ white Pin-A5 on Violet plug at BCM** +
FACTORY ARM See notes****
BRAKESWITCH White At switch above brake pedal +
PARKLIGHTS Brown Pin-A1 on Lt.blue plug at BCM** +
HAND BRAKE Lt.blue Pin-B2 on Lt.blue plug at BCM** -
HORN Black Pin-B7 on Brown plug at BCM** -
CLUTCH SWITCH Purple At switch on top of clutch pedal Type 1
DRIVER WINDOW UP Dk.blue At switch in driver's door REV POL
DRIVER WINDOW DOWN Brown At switch in driver's door REV POL
PASSENGER WINDOW UP Blue or Blue/white At switch in driver's door REV POL
PASSENGER WINDOW DOWN Tan At switch in driver's door REV POL
LEFT REAR WINDOW UP Dk.green At switch in driver's door REV POL
LEFT REAR WINDOW DOWN Purple At switch in driver's door REV POL
RIGHT REAR WINDOW UP Lt.green At switch in driver's door REV POL
RIGHT REAR WINDOW DOWN Purple or PURPLE / white At switch in driver's door REV POL
HEADLIGHTS Dk.blue Pin-B6 on Lt.blue plug at BCM** -
REVERSE LIGHTS Lt.green DKP in harness to back of vehicle +
DIMMER Gray At dimmer switch harness +
VSS WIRE Dk.GREEN / WHITE In large BLACK plug next to left shock tower 4000ppm
KEY SENSE Lt.green Pin-B12 on Brown plug at BCM** -
DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash DATA
Vehicle notes
PLEASE NOTE: This vehicle is equipped with GM's PASSLOCK II anti-theft system. Refer to the SECURITY diagram before any remote start installation.
* On the 2.2L engine this wire is found at the distributor on the left side of the engine. On the 2.4L, the tach is found in the large split loom tube passing near the battery. On the 2.4 L4 engine, the tach is found at a connector on the top of the engine. (See exploded views)
** A variety of wires can be easily accessed at the vehicle's body control module found above the driver's kick panel. See the BCM diagram for details.
*** Driver's door is LT.GREEN/ BLACK (pin-A7 on violet plug at BCM). LT.BLUE covers all other doors (pin-A8 on violet plug at BCM). These wires should be isolated with 1N4001 diodes when connecting together. See the BCM diagram.
**** The vehicle may be equipped with a content theft-deterrent alarm system. This alarm cannot be armed or disarmed except with the factory transmitter. However, the system will disarm when the ignition is energized. Therefore, a remote starter can be added without any concern for disarming the factory alarm.
***** Must be connected for remote start.
Note: The information on this sheet is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Wiremagic.com Corporation and/or any associated or unassociated individual or corporation who furnishes this document and/or software assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and Wiremagic.com Corporation and/or any associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly, or in any other way. The information supplied is a guide only.
©2002 Autoland All rights reserved
Printed at: 10/9/2004 9:05:14 PM
Posted By: Teken
Date Posted: October 09, 2004 at 8:09 PM
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / CAVALIER / 2003 / Remote Start
12volts red   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition
Third Ignition
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense
Power Lock lt. blue      either kick panel
Notes: Non keyless cars, locks are 5wi (type C) and they are mastered from the passenger side switch. Keyless cars, locks are positive trigger (type A). Also found at the BCM.
Power Unlock white      either kick panel
Lock Motor gray   5wi driver kick, door harness
Unlock Motor tan   5wi driver kick, door harness
Parking Lights+ brown   +   driver kick, harness to rear
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger GREEN/ black & lt. blue   -
Notes: The GREEN/ black is located in the lower driver kick panel. It catches the driver door only. The lt. blue is located in the passenger kick panel, and catches the passenger door (s). Tap both wires and diode isolate each. Also found at the BCM.
Dome Supervision use door trigger
Trunk/Hatch Pin black   -   light in trunk
Hood Pin
Trunk/Hatch Release BLACK/ white   +   BCM
Notes: The BCM (Body Control Module) is located to the left of the steering column above the driver kick panel.
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer PURPLE / white   ac   engine harness
Notes: The engine harness is found next to the battery, below the radiator hose, just above the transaxle.
Wait to start N/A
Brake Wire white   +   brake pedal switch
Parking Brake
Horn Trigger black   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 555L or 555T
Notes: N/A
Posted By: Teken
Date Posted: October 09, 2004 at 8:10 PM
Chevrolet
Cavalier
2000-2004
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   YELLOW (+)
IGNITION SWITCH HARNESS
Ignition #1:
   PINK (+)
IGNITION SWITCH HARNESS*
Ignition #2:
   N/A
Ignition #3:
   N/A
Accessory:
   ORANGE (+)
Brake Light:
   WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   PURPLE / WHITE
ENGINE HARNESS NEXT TO THE BATTERY BELOW THE RADIATOR HOSE
Parking Lights:
   BROWN (+)
AT REAR OF LIGHT SWITCH OR DRIVER KICK PANEL
Headlights:
OEM Alarm Disarm:
   DISARMS WHEN VEHICLE IS
STARTED EITHER BY THE KEY OR REMOTELY
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
   N/A
Clutch Bypass Wire:
Notes:
   *This vehicle is equipped with GM's PASSLOCK II Anti-Theft system. Use Universal Alarm Bypass Module part # 2x402 where X can be any number.
Chevrolet
Cavalier
2000-2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   RED
Starter Kill:
   YELLOW (+)
Ignition +12 Volts:
   PINK (+)
Dome Lights/Superv:
   L GRN/BLK & L BLUE (-)
AT BCM UNDER LEFT SIDE OF DASH ***
OEM Horn:
   BLACK (-)
STEERING COLUMN HARNESS
Power Lock:
   LT. BLUE
Power Unlock:
   WHITE
Trunk Release:
   BLACK/ WHITE (+)
AT BCM UNDER LEFT SIDE OF DASH****
Alarm Input Wire:
Notes:
** Without OEM Keyless, See Note # 203 - Reverse Polarity Door Lock Diagram. With OEM Keyless, See Note #202 - Positive Pulse Door Lock Diagram. *** L GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. Alternatively connect the alarm input wire to the domelight in the roof **** Use BLACK/ White for 2003 models.
Posted By: Teken
Date Posted: October 09, 2004 at 8:12 PM
https://www.directechs.com/guides/manuals/ig/python/N552P.pdf
This is the installation guide for the unit specified, assuming you do not have it.
Regards
EVIL Teken . . .
Posted By: mo12v
Date Posted: October 09, 2004 at 8:22 PM
How about this too:
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightRED / WHITE (-)AT ANTI-THEFT MODULE BEHIND GLOVEBOX
Trunk Pin SwitchBLACK (+)AT LIGHT IN TRUNK
Parking LampBROWN (+)AT HEADLIGHT SWITCH
Power LockLIGHT BLUEPASSENGER
Power UnlockWHITEKICK PANEL
Reversal Rest At Ground Door Lock
Accessories
Window Up
Window Down
Ign Key WarnLIGHT GREEN (-)IGNITION SWITCH HARNESS
Trunk ReleaseBLACK/ WHITE (+)AT MODULE IN LEFT SIDE OF TRUNK
OEM Horn
HeadlightsDARK BLUE (+)AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm Disarm
 Positive Pulse Trunk Release Circuit
Remote Start
Tach SignalWHITELARGE HARNESS ON FRONT OF ENGINE
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3
AccessoryORANGEIGNITION SWITCH HARNESS
Neutral SafetyYELLOW (-)IGNITION SWITCH HARNESS
Brake LightWHITE (+)AT SWITCH ABOVE PEDAL
Reverse LightLIGHT GREEN (+)IN HARNESS TO TRANSMISSION
Rear Window Defrost
 General Motors Passlock ll
MO
Date Posted: October 09, 2004 at 9:05 PM
hay thanks guys
Posted By: Teken
Date Posted: October 10, 2004 at 1:55 AM
No problem . . .
