Retained Accessory Power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40605
Printed Date: April 20, 2026 at 4:36 PM
Topic: Retained Accessory Power
Posted By: cfvwd
Subject: Retained Accessory Power
Date Posted: October 09, 2004 at 10:41 PM
Can any one tell me where I can find RAP in my 2003 GMC truck, it has a in dash RDS 6 disc changer.
I need the RAP to power my XM sat receiver, I have been to all the usual places and no luck, I have been told that it is not possible to get RAP as all accesorys are powered of the bat and then are turned on or off by the BCM or door modules.
I have also been told that the guys at PAC make a interface cable for an aux audio in that also provides RAP.
Does any one have what kind of a signal there is on the data buss line.
Posted By: jstruckman
Date Posted: October 13, 2004 at 8:23 PM
The RAP relay is controlled by the Class 2 data bus, there is no way to tap into it directly. For the installs i do in GM vehicles i now use an interface by Soundgate called the GMACC. This is an interface that reads the data bus and provides you with a 12 volt turn on. It works great, saves me alot of time and trouble
Jazzy
