94 Chevy S-10
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40921
Printed Date: April 18, 2026 at 2:17 PM
Topic: 94 Chevy S-10
Posted By: Strykrincognito
Subject: 94 Chevy S-10
Date Posted: October 14, 2004 at 10:48 PM
    Greets,
       I was looking for the wiring specs for a '94 Chevy S-10, and and tips or tricks for that model of light truck for the installation of a remote starter / alarm combo.  (I've removed my nice DEI Sidewinder from it's dead host, and I'm looking to reinstall myself.)
     I've acquired the install manuals, etc. and I have a Chiltons for the truck, I was just looking for specifics, (ignition wires, colors, safety for the auto-tranny in the steering column, etc).
    Also, I've also removed the aftermarket door solenoids, and any tips on that would be great.
    Chaulk the replies to this up to : "Everything you might want to know when installing a remote starter/alarm in a 94 s-10."
Thanks in advance.
Posted By: mo12v
Date Posted: October 15, 2004 at 8:55 AM
This is what I have:
Constant 12 voltsRED AND REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOW OR PURPLEIGNITION SWITCH HARNESS
Dome LightWHITE OR WHT/BLACK (-)DRIVER PIN SWITCH OR COURTESY LIGHT
Trunk Pin SwitchN/A
Parking LampBROWN(+) AT HEADLIGHT SWITCH
Power LockLIGHT BLUEDRIVER KICK PANEL
Power UnlockBLACK OR BLACK/ WHITEDRIVER KICK PANEL
Reversal Rest At Ground Door Locks
Accessories
Window UpD\ D BLUE P\ D BLUE/WHITE @ MAIN #211
Window DownR/ BROWN S/ TAN SWITCH
Ign Key WarnLIGHT GREEN (-)STEERING COLUMN HARNESS OR CHIME MOD.
Trunk ReleaseN/A
OEM HornBLACK (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsYELLOW (+)HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
 Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalWHITEAT DISTRIBUTOR
Ignition #2ORANGEIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACKSWITCH NEAR BASE OF STEERING COLUMN
Brake LightWHITE (+)SWITCH ON BRAKE PEDAL SUPPORT BRACKET
Reverse LightLIGHT GREEN (+)SWITCH NEAR BASE OF STEERING COLUMN
Rear Window Defrost
MO
Date Posted: October 15, 2004 at 10:32 AM
   Hey Mo, Thanks for fast response and the info, I'll be digging into this one soon enough (I want to get this unit installed before the REALLY cold weather comes along!)
I appreciate it,
--Si
