2000 Silverado lock/ unlock info.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41842
Printed Date: May 11, 2026 at 8:13 AM
Topic: 2000 Silverado lock/ unlock info.
Posted By: joneill
Subject: 2000 Silverado lock/ unlock info.
Date Posted: October 28, 2004 at 6:47 PM
I'm installing a remote start with keyless entry, but i can not figure out what wires to i need to tie to for the lock/unlock function. According to the install manual i need to hook to the lock motor as well as the lock switch wires. Any help i can get would be great.  Thanks   The remote system is mfg. by bulldog security.  John
Posted By: mo12v
Date Posted: October 28, 2004 at 11:08 PM
Depending if you alredy have Factory Keyless Entry & if it is 2 or 4 door, You may need 2 SPDT Relays for Door Locks
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightWHITE (-) BASE MODELTAN (Dr) LT BLUE (-) LUXURY *
Trunk Pin SwitchN/A
Parking LampBROWN (+)AT HEADLIGHT SWITCH **
Power LockL BLUEHIGH IN DRIVERS
Power UnlockWHITEKICK PANEL
* At Light Control Module Behind Center Dash, Diode Isolate Door Trigger Inputs! If Factory Alarm Is Triggered On Unlock Command See Tech Note * ** Or Headlight Control Module (Luxury Model Has Headligtht Control Module Behind Drivers Dash By Door Lock Relay).
Positive Pulse Door Locks (2 Door w/Keyless or 4 Door)
Reversal Rest At Ground Door Lock (2 Door w/o Keyless)
Accessories
Window UpD\ D BLUE P\L BLUE @ MAIN SWITCH
Window DownR/ BROWN S/TAN
Ign Key WarnL GREEN (-)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsWHITE (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmL GREEN (-)AT BCM UNDER DRIVERS DASH
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalWHITEAT ENGIN HARNESS INLINE TO I/P *
Ignition #2WHITEIGNITION SWITCH HARNESS (TRANS)
Ignition #3ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostN/A
* Located Under Drivers Dash In Pin E8 At Bottom Right Of The Connector. Glow Plug : DARK GREEN At Light. Passlock II
MO
