diagram:pontiac grand am 1996
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42481
Printed Date: April 12, 2026 at 6:25 PM
Topic: diagram:pontiac grand am 1996
Posted By: jpmm
Subject: diagram:pontiac grand am 1996
Date Posted: November 08, 2004 at 1:28 AM
I can't find the elctrical diagram of pontiac grand am model 1996. Maybe someone can help me.
I appreciate much your help.
yours truly,
JPM
jpm
Posted By: mo12v
Date Posted: November 08, 2004 at 7:15 PM
OK
Constant 12 voltsRED (2)IGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightL GRN/BLK & L BLUE (-)AT CONVENIENCE CENTER MODULE *
Trunk Pin SwitchORANGE / BLACK (-)AT LIGHT IN TRUNK
Parking LampBROWN (+)AT HEADLIGHT SWITCH
Power LockL BLUE24 PIN GRAY CONNECTOR
Power UnlockWHITEIN DRIVER KICK PANEL
* Convenience Center Module Located Behind Driver Dash To Left Of Steering Column. L GREEN/ BLACK (-) Covers Driver Door, L BLUE (-) Covers All Other Doors. Diode Isolation Needed: Cathode (Band) Side Of Diode Faces OEM Wires. See Tech Notes For Additional Notes On Dome Light Circuit.
Positive Pulse Door Locks
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN SWITCH
Window DownF/ BROWN F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)STEERING COLUMN HARNESS
Trunk ReleaseBLACK (+)AT OEM KEYLESS MODULE *
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsTAN (LO) & GREEN (HI)(+) AT HEADLIGHT SWITCH
OEM Alarm ArmN/ANO OEM ALARM PRESENT
OEM Alarm DisarmN/AIN SCHEMATICS
Reversal Rest At Ground Power Window Circuit . * BLACK (+) At OEM Keyless Module Located In Trunk. Without OEM Keyless Trunk Release Is Cable Operated.
Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT POWERTRAIN CONTROL MODULE *
Ignition #2ORANGEIGNITION SWITCH HARNESS
Ignition #3WHITEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACK (-)AT SWITCH ON TRANSAXLE **
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT SWITCH ON TRANSAXALE **
Rear Window DefrostL BLUE (+)AT REAR DEFOGGER SWITCH
* 6 Cylinder Engine Tach Wire Is WHITE Or PURPLE / WHITE At Powertrain Control Module (PCM), 4 Cylinder Tach Wire Is WHITE At PCM. PCM Located Behind Passenger Dash On Both. ** ORANGE / BLACK (-) And L GREEN (+) Are Both Located In 24 Pin Gray Connector In Driver Kick Panel.
G.M. Passlock
MO
Posted By: jpmm
Date Posted: November 08, 2004 at 11:32 PM
Good day!  I need help. I need a wiring diagram of 1996 pontiac grand am. the pannel gauge was damage. Your help is much appreciated. Thank you
charles
jpm
Posted By: jpmm
Date Posted: November 08, 2004 at 11:50 PM
I need a wiring diagram of 1996 pontiac grand am pannel gauge.
Thank you... charles
jpm
