2004 Chrysler Intrepid Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42630
Printed Date: April 23, 2026 at 5:36 AM
Topic: 2004 Chrysler Intrepid Alarm/Remote Start Wiring
Posted By: malucyk
Subject: 2004 Chrysler Intrepid Alarm/Remote Start Wiring
Date Posted: November 09, 2004 at 8:43 PM
Can someone post a wiring diagram for a 2004 Chrysler Intrepid.
MAtt
Posted By: mo12v
Date Posted: November 10, 2004 at 8:36 AM
This is for Dodge Intrepid
I use OMEGA ByPASS # DB-CHDL-2PK for Transponder and Door Locks
Constant 12 voltsRED & PINK/BLACKIGNITION SWITCH HARNESS
Ignition 12 voltsD BLUE/WHITEIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightYELLOW (-)AT EITHER KICK PANEL OR BCM *
Trunk Pin SwitchTAN/BLACK (-)22 PIN CONNECTOR HIGH IN DRIVER KICK
Parking LampBLACK / YELLOW (+)AT BODY CONTROL MODULE *
Power LockWHITE/ D GREEN16 PIN CONN. IN ACCESS HOLE **
Power UnlockSINGLE WIRE SYSTEMIN DRIVER KICK OR HIGH IN DR.KICK
* Body Control Module (BCM) Located Behind Fuse Box. **Door Locks Require +12v Pulse Thru 2.7K Ohm Resistor For Lock And +12V Pulse Thru 620 Ohm Resistor For Unlock.
Single Wire Resistor Door Lock System
Accessories
Window UpD\ WHITE P\ VIO/WHT D\ RED / BLK P\ GRN/WHT @ MAIN SWITCH
Window DownF/ L BLUE F/ BRN/WHT R/ BLU/WHT R/ GRY/BLK
Ign Key WarnLT BLUE (-)IGNITION SWITCH HARNESS OR BCM *
Trunk ReleaseBLACK/ WHITE (+)AT SWITCH OR BODY CONTROL MODULE **
OEM HornBLACK/ RED (-)STEERING COLUMN HARNESS
HeadlightsVIOLET OR VIO/RED (+)AT BODY CONTROL MODULE **
OEM Alarm ArmSINGLE WIRE SYSTEM
OEM Alarm DisarmL GREEN/ ORANGEDRIVER KICK PANEL OR BCM ** ***
* Wire Found In BLACK 24 Pin Connector At BCM ** Body Control Module (BCM) Located Behind Center Of Dash. *** LT GREEN/ ORANGE Wire Must See A 12V (+) Pulse Thru A 587-681 Ohm Resistor To Disarm OEM Alarm (From Install). Wire Found In BLUE 16 Pin Connector.
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalSEE NOTE *AT POWERTRAIN CONTROL MODULE **
Ignition #2D GREEN/ REDIGNITION SWITCH HARNESS
Ignition #3BLACK/ ORANGEIGNITION SWITCH HARNESS
AccessoryBLACK/ WHITEIGNITION SWITCH HARNESS
Neutral SafetyBLK/WHT OR BRN/YEL (-)AT SWITCH ON TRANSMISSION OR PCM **
Brake LightWHITE/ TAN (+)AT SWITCH ABOVE BRAKE PEDEL
Reverse LightVIOLET/BLACK (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostDK BLUE/WHITE (-)BCM 16 PIN BLUE CONN PIN #14
* Independent Coil System, TAN/PINK, TAN/L GREEN, TAN/L BLUE, TAN/RED, TAN/ORANGE, & TAN/D GREEN. Each Wire Is A Single Cylinder Signal. ** Powertrain Control Module (PCM) Located On Driver Side Front Fender Near Power Distribution Block.
Immobilizer Bypass
MO
