2002 Camry wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45904
Printed Date: May 13, 2026 at 3:59 PM
Topic: 2002 Camry wiring diagram
Posted By: firenhp
Subject: 2002 Camry wiring diagram
Date Posted: December 23, 2004 at 11:35 PM
Looking for wiring diagram of the 2002 Camry. Also, will I need a bypass of any type to put in a remote starter system? I've never done a car this new before.
Thanks, Noah
Posted By: KarTuneMan
Date Posted: December 24, 2004 at 1:53 AM
12volts
 WHITE/ red
 ignition harness
Starter BLACK/ white  +  ignition harness
Second Starter BLACK / YELLOW  +  ignition harness
Ignition BLACK/ red  +  ignition harness
Second Ignition BLACK / YELLOW  +  ignition harness
Third Ignition N/A
Accessory blue/red  +  ignition harness
Second Accessory N/A
Keysense blue  -  ignition harness
Power Lock blue / YELLOW  -  driver kick, door harness
Power Unlock blue (double pulse)  -  driver kick, door harness
Lock Motor blue/red  5wi driver kick, door harness
Unlock Motor blue/black  5wi driver kick, door harness
Parking Lights+ green  +  bottom of fuse box
Date Posted: December 24, 2004 at 1:58 AM
12volts WHITE/ red  +  ignition harness
Third Ignition N/A
Notes: Using the status output wire from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Notes: These wires will meter while turning the key in the driver door key cylinder.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/white (-) in the passenger kick, door harness.
Parking Lights- red  -  headlight switch
Hazards lt. GREEN/ black  -  flasher relay in driver kick
