wiring for mercedes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=468
Printed Date: April 18, 2026 at 8:57 PM
Topic: wiring for mercedes
Posted By: wicked_4x4
Subject: wiring for mercedes
Date Posted: April 26, 2002 at 9:08 AM
Hey,
Does anybody have the wiring diagram for a 1991 Mercedes 190E?  I'm doing an alarm install on it myself. Yes, I'm that crazy! For some reason I can't get the power door locks to work with the alarm. I'm wiring it with two relays exactly the way the diagram shows for a Mercedes vacuum type system.
Scorpion
Posted By: Velocity Motors
Date Posted: April 26, 2002 at 9:23 AM
Mercedes-Benz
190D & 190E
1984-1992
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
VIOLET/WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
RED / BLACK
Ignition #2:
RED / YELLOW
Ignition  #3:
N/A
Accessory:
RED / GREEN
Brake  Light:
BLACK/ RED
(+) AT BRAKE SWITCH
Tach  Signal:
GREEN/ YELLOW
AT IGNITION CONTROL MODULE
Parking Lights:
GRAY/WHITE (DR) &
GRAY (PS) (+) AT HEADLIGHT SWITCH***
Headlights:
WHITE/ YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
Mercedes-Benz
190D & 190E
1984-1992
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED AND RED
Starter  Kill:
VIOLET/WHITE
Ignition  +12 Volts:
RED / BLACK
Dome  Lights/Superv:
BROWN / GRAY AND GRAY
SEE NOTES BELOW *
OEM Horn:
BLACK / YELLOW/PINK (+)
STEERING COLUMN HARNESS
Power  Lock:
GREEN, BLUE OR YELLOW
ALL THREE WIRES ARE AT VACUUM PUMP
Power  Unlock:
VACUUM DOOR LOCKS
Trunk  Release:
NO COLOR AVAILABLE
Alarm  Input Wire:
SEE NOTES BELOW *
Notes:
* Rear Pin Switch And BLUE Door Lock Wire Can Be Found Below Driver Step Plate In Protective Tubing. *** Split Parking Light System.
