Security wire - 2000 Jimmy
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48830
Printed Date: April 19, 2026 at 5:00 PM
Topic: Security wire - 2000 Jimmy
Posted By: Flatlandfreak
Subject: Security wire - 2000 Jimmy
Date Posted: January 28, 2005 at 8:15 PM
  I cannot seem to find the OEM disarm wire in my jimmy.  I know it is light green.  I had a friend of mine who is an installer look for it and we looked behind the center console near the BCM where he says he always finds it.  There were 4 light green wires.  We tested all of them and none of them seemed to be what we wanted.  One was the "key-in" wire, one was a lock/or unlock  wire and the other one made the parking lights come on or something (cant really remember).  and the fourth we couldnt identify exactly.  We tested them by setting off the alarm and then attaching each wire to ground.  If we had the right wire this should disarm it right?  Because the disarm is a negative pulse?   I know it says it is located in the kick panel on the driver's side, but its near impossible to get into the kick panel and access any wires.
Any help would be greatly appreciated!
I Like Peanut Butter!
Date Posted: January 30, 2005 at 3:07 PM
No one has any ideas? posted_image
Posted By: johnnydi77
Date Posted: January 30, 2005 at 7:44 PM
Make sure you have security first of all......in that truck the wire is lt/green and is in the purple plug of the BCM to the right on the steering column under the radio. It will be the top plug.
John J. DiStefano Jr.
Date Posted: February 01, 2005 at 9:03 PM
Well I found it.  I didnt pull the panel completely off and didn't notice the 3rd wiring harness.  I only saw the 2.  Everything is all up and working properly now.  Thanks.
