92-93 landcruiser wiring diagrams
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=50327
Printed Date: April 19, 2026 at 7:02 AM
Topic: 92-93 landcruiser wiring diagrams
Posted By: infra482002
Subject: 92-93 landcruiser wiring diagrams
Date Posted: February 17, 2005 at 5:09 PM
Hi all.
I have afriend who isn't computer savvy who has asked me to find wiring diagrams for his 92-93 80 series landcruiser. He is having all kinds of intermittent faults with his radio, clock and interior light. They only seem to work when he goes around corners.
Any diagrams yuo may have for him, especially wiring looms would be greatly appreciated.
I allready have the stereo diagram off the database.
Thanks in advance guys
Posted By: thepencil
Date Posted: February 17, 2005 at 9:20 PM
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / LAND CRUISER / 1993 / Remote Start
[PRINT THIS PAGE]
12volts black - WHITE/ red    +   ignition harness
Starter BLACK/ white    +   ignition harness
Second Starter
Ignition BLACK / YELLOW    +   ignition harness
Second Ignition blk/grn or blk/red    +   ignition harness
Third Ignition
Accessory blue/red    +   ignition harness
Second Accessory
Keysense
Power Lock blue/black    -   driver door harness in kick
Power Unlock blu/yel & blu/org    -   driver door harness in kick
Notes: Both wires must be used and diode isolated.
Lock Motor
Unlock Motor
Parking Lights+ green      drivers kick
Parking Lights- RED / black      steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / yellow    -   back of cluster
Notes: May also be found RED / blue or white in top of the fuse box in a harness from domelight. Use RED / blue for dome supervision.
Dome Supervision
Trunk/Hatch Pin tied with door
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer black    ac igniter or check conn
Notes: Check connector is on the passenger side firewall near wiper motor. Igniter is by brake master cylinder.
Wait to start
Brake Wire GREEN / WHITE    +   brake switch
Parking Brake
Horn Trigger GREEN/ blue    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / LAND CRUISER / 1992 / Remote Start
[PRINT THIS PAGE]
Second Starter
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.posted_image
