Wiring Diagram for 2002 Camry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5123
Printed Date: May 03, 2026 at 9:30 AM
Topic: Wiring Diagram for 2002 Camry
Posted By: asianboi
Subject: Wiring Diagram for 2002 Camry
Date Posted: November 04, 2002 at 12:04 PM
I've tried to look for the wiring diagram for the 02 camry in the diagrams section, but I did not find anything.  If anyone has it, please help out this poor guy. Thanks in advance!
brian
Posted By: Velocity Motors
Date Posted: November 04, 2002 at 12:57 PM
|              12V|WHITE/ red           |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|   SECOND STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|  SECOND IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|blue / YELLOW         |-  |driver kick panel           |
|     POWER UNLOCK|blue *1             |-  |driver kick panel           |
|       LOCK MOTOR|blue/red            |   |driver kick panel           |
|     UNLOCK MOTOR|blue/black          |   |driver kick panel           |
|    DISARM DEFEAT|blue/black          |   |DKP, harness to rear        |
| PARKING LIGHTS +|green               |   |bottom of fuse box          |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|*2                  |-  |*2                          |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|green               |-  |DKP or light in trunk       |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|WHITE/ blue          |5wi|driver kick panel           |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|                    |   |                            |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|GREEN / WHITE         |+  |bottom of fuse box          |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  *1 Unlock requires a double pulse.  *2 The driver door trigger is RED / green at lower left of the fuse box. The passenger door is RED / green at upper left of the fuse box. The rear door trigger is RED / white at the bottom of the fuse box. Use all three and diode isolate each.
Posted By: asianboi
Date Posted: November 04, 2002 at 1:15 PM
Thanks for your help Jeff.
The reason that I need the wiring diagram is because I have to install a keyless entry system for my uncle.  Are these:
the one for the lock and unlock door wires?
Date Posted: November 05, 2002 at 12:33 AM
Yes these are the correct wires for the keyless entry wires.
