99 F350 Wiring Guide Request
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51543
Printed Date: May 05, 2026 at 1:10 AM
Topic: 99 F350 Wiring Guide Request
Posted By: Sierra2700
Subject: 99 F350 Wiring Guide Request
Date Posted: March 08, 2005 at 3:04 PM
I already have a wiring guide, but I want to verify it is correct. The wiring guide I have says for 7.3Liter diesel.
I also found this guide, but its for a 2000, and has different wire colors then my guide: https://www.the12volt.com/installbay/forum_posts.asp?tid=9069&KW=f350
Also what diode should I buy to diode isolate the wait to start wire?
And yes I did a search for this wiring guide already.
Posted By: thepencil
Date Posted: March 08, 2005 at 9:32 PM
"Also what diode should I buy to diode isolate the wait to start wire?"
1 amp will do. 1N4004
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 1999 / Remote Start
12volts yellow & lt. GREEN/ purple   +   ignition harness
Starter RED / lt. blue   +   ignition harness
Second Starter N/A
Ignition RED / black (larger of 2)   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ lt. green   +   ignition harness
Second Accessory gray / YELLOW   +   ignition harness
Keysense BLACK/ pink   -   ignition harness
Power Lock pink / YELLOW
Notes: Non-keyless versions are 5 wire located in the driver door harness. Keyless versions are negative trigger located in a gray molex plug to the right side of the steering column.
Power Unlock pink/lt. green
Lock Motor pink/black   5wi driver kick, door harness
Unlock Motor pink/black or RED / orange   5wi driver kick, door harness
Parking Lights+ brown   +   headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light BLACK/ pink   +   relay box under hood
Door Trigger BLACK/ lt. blue   +   gray plug right of column
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer WHITE/ pink   ac   instrument cluster or PCM
Notes: Can also be located in the main harness that runs on the inside of the firewall to the left of the brake pedal.
Wait to start BLACK/ pink   -   instrument cluster or PCM
Notes: This wire MUST be diode isolated from the instrument cluster to keep the battery from draining, see DirectFax document 1090.
Brake Wire lt. green   +   brake pedal switch
Parking Brake
Horn Trigger dk. blue   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: March 08, 2005 at 10:06 PM
Thanks pencil. As always, your always a help on the forum.
