need comp wirring diag for 2001 silvarad
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53428
Printed Date: April 23, 2026 at 6:05 AM
Topic: need comp wirring diag for 2001 silvarad
Posted By: lois green
Subject: need comp wirring diag for 2001 silvarad
Date Posted: April 06, 2005 at 9:19 PM
Need wirring harness diagram for 2001 silvarado truck 3500 or serra. diseal 6.5. starts than dies. need help
lois green
Posted By: thepencil
Date Posted: April 06, 2005 at 9:42 PM
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / SILVERADO / 2001 / Remote Start
12volts red   +   ignition harness
Starter yellow   +   ignition harness
Second Starter
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition
Accessory orange   +   ignition harness
Second Accessory
Keysense
Power Lock lt. blue   +   brown plug at BCM
Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
Power Unlock white   +   brown plug at BCM
Lock Motor gray      driver kick panel
Unlock Motor tan      driver kick panel
Parking Lights+ brown   +   lt. blue plug at BCM
Parking Lights- white   -   lt. blue plug at BCM
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger     -   BCM
Notes: Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm lt. green   -   driver kick panel
Notes: Also found in the purple plug of the BCM.
Disarm No Unlock
Tachometer white      ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector.
Diesel tach wire is white at the cluster.
Wait to start dk. blue   -   instrument cluster
Notes: See DirectFax document 1090.
Brake Wire white   +   brake pedal switch
Parking Brake
Horn Trigger black   -   brown plug at BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.posted_image
