1999 firebird, power windows
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53934
Printed Date: April 30, 2026 at 7:10 AM
Topic: 1999 firebird, power windows
Posted By: infiniteways196
Subject: 1999 firebird, power windows
Date Posted: April 14, 2005 at 8:38 PM
I need the schematic for the power windows of a 1999 pontiac firebird. Can anyone help me please?
Posted By: thepencil
Date Posted: April 15, 2005 at 8:01 AM
Not very much, but hopefully you can make some use of the schematic.
DIRECTWIRE™ WIRING INFORMATION - PONTIAC / FIREBIRD / 1999 / Accessory
12volts red (50A)   +   ignition harness
Ignition pink   +   ignition harness
Parking Lights+ brown   +   blue plug at the BCM
Notes: The BCM is located in the passenger kick, just in front of the blower motor.
Parking Lights- BLACK/ white   -   blue plug at the BCM
Notes: Not all models include this circuit.
Headlight yellow   +   headlight switch
Trunk/Hatch Release brown   +   blue plug at the BCM
Power Sliding Door N/A
Speed Sense dk. GREEN / WHITE   4K   cruise control module or PCM
Wipers gray   +   steering column
LF Window up/dn dk. blue - brown   A   driver window motor in door
RF Window up/dn lt. blue - tan   A   driver kick, door harness
LR Window up/dn N/A
RR Window up/dn N/A
Sun Roof open/close purple - gray   5wi folding top switch
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: VATS Part #: 652T resistor pack
Notes: See DirectFax document 1049 for interface information.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
