2001 hyundai accent wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53977
Printed Date: April 30, 2026 at 10:30 AM
Topic: 2001 hyundai accent wiring
Posted By: mirtz
Subject: 2001 hyundai accent wiring
Date Posted: April 15, 2005 at 3:48 PM
were can i find the wiring diagram to hyundai accent 2001 1.3l
luis ferreira
Posted By: boomer_106
Date Posted: April 15, 2005 at 5:47 PM
Is this what you're looking for?
Hyundai
Accent
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
GREEN
Ignition #2:
YELLOW
Ignition  #3:
N/A
Accessory:
BLUE
Brake  Light:
PINK/BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLUE OR BROWN
AT IGNITION COILS
Parking Lights:
GREEN (-)
HEADLIGHT SWITCH
Headlights:
YELLOW (-)
HEADLIGHT SWITCH
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
Hyundai
Accent
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
OEM Alarm Disarm:
N/A
Dome  Lights/Superv:
GREEN (-)
DRIVER'S KICK PANEL OR CLUSTER
OEM Horn:
BLUE/ORANGE (-)
STEERING COLUMN HARNESS
Power  Lock:
BLACK/ ORANGE (-)
AT ETACS MODULE LEFT OF STEERING COLUMN *
Power  Unlock:
YELLOW (-)
Trunk  Release:
N/A
Alarm  Input Wire:
GREEN (-)
Notes:
* These Wires Only Exist On Vehicles That Are Equipped With Factory Keyless Entry. For Vehicles Not Equipped With Factory Keyless Entry An Actuator Must Be Installed Into The Driver's Door. See Installation Note #204 - Adding Actuators Door Lock Diagram.
Posted By: mirtz
Date Posted: April 18, 2005 at 4:52 PM
thanks a lot boomer_106 .i´´m looking for shematics because i can´t find the wires of the ''turning direction'' lights .i i´m instaling a non hyundai alarm  to make my car keyless .every thing is ok unless the turning lights because i've look beind and the wires color is GREEN/ yelow and i dont know were they come from
because i've looked for that wires in the front of the car and i dont found them.and i want the shematics because  i want to put some electronics in the car .if you need i can make almost all kind of electronics for car like light delays or other kind of things .
luis ferreira
Date Posted: April 18, 2005 at 10:29 PM
Did you try looking at the turn signal lever?
Posted By: mirtz
Date Posted: April 19, 2005 at 4:25 PM
well i didn't have too much time to look for it but i'm going to try wen i have some.thanks any way but what i realy was looking for was the shematics.
luis ferreira
