stereo wiring diagram for 86 laser
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5650
Printed Date: April 02, 2026 at 2:04 AM
Topic: stereo wiring diagram for 86 laser
Posted By: madwog
Subject: stereo wiring diagram for 86 laser
Date Posted: November 19, 2002 at 3:21 PM
need help guy's, need stereo wiring diagrams for any 86 model lasers.
thanks.
Posted By: Velocity Motors
Date Posted: November 20, 2002 at 12:29 AM
This is for the '84 Plymouth Laser:
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue            |+  |ignition harness            |
|  SECOND IGNITION|                    |+  |ignition harness            |
|        ACCESSORY|BLACK/ red           |+  |ignition harness            |
|       POWER LOCK|orange              |5wi|drivers kick panel          |
|     POWER UNLOCK|pink                |5wi|drivers kick panel          |
| PARKING LIGHTS +|BLACK / YELLOW        |   |light switch                |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|yellow              |-  |drivers door pin            |
|  TRUNK/HATCH PIN|tan/black           |-  |harness to rear             |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|BLACK / YELLOW        |   |ignition coil               |
|       BRAKE WIRE|WHITE/ tan           |+  |brake switch                |
|     HORN TRIGGER|dk. GREEN/ red       |+  |horn relay *1               |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|dk.green - purple   |A  |at switch                   |
|  RF WINDOW UP/DN|dk.blue - purple    |A  |at switch                   |
Notes:
*1 Horn relay is at the bottom of the fuse box. Also find BLACK/ red (-) at steering column.
