1990 Cadillac Brougham stereo install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57440
Printed Date: April 18, 2026 at 5:32 PM
Topic: 1990 Cadillac Brougham stereo install
Posted By: dhorsley
Subject: 1990 Cadillac Brougham stereo install
Date Posted: June 10, 2005 at 2:07 PM
Hey guys,
I have run into a problem with a customers car. This Cadillac has a wierd harness that goes into the back of the stereo. This harness does not match any kits that I have from American International, Scoche, or Metra. I ran a test light on the factory harness to find 3 constant power wires. What in the heck is going on? Please help!
Posted By: chriswallace187
Date Posted: June 10, 2005 at 2:54 PM
I remember doing some older DeVilles and they had a harness that was basically like Metra's 70-1677-1 but then they had another connector with a power wire output and some illumination wires in it. It wasn't the same car, but I'd still test all the wires at the radio with the lights on and off if you haven't already. Hope this helps.
Posted By: dhorsley
Date Posted: June 10, 2005 at 3:59 PM
I did a search for Metra application for this car and came up with a 70-1856 which states it is 204" long. It is also called a tuner bypass. Guess Im off to finding the tuner.
Date Posted: June 11, 2005 at 2:29 AM
The later model Caddys usually had it mounted in the trunk somewhere, underneath the rear deck usually. I'd guess your Brougham is probably the same.
