VSS - 05 Acura TSX no Nav
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58437
Printed Date: April 18, 2026 at 10:01 PM
Topic: VSS - 05 Acura TSX no Nav
Posted By: eschamp
Subject: VSS - 05 Acura TSX no Nav
Date Posted: June 27, 2005 at 11:28 AM
I am looking for information about the location of the VSS wire(s) for a 2005 Acura TSX without the navigation system.
Thanks.
Posted By: teke0611
Date Posted: July 09, 2005 at 5:54 PM
Unfortunately, the TSX transmission does not have a VSS at all.  posted_image  Vehicle speed is calculated by the ecu from the input on the mainshaft sensor in the transmission, like the K series Accord and brand new RSX.
Posted By: eschamp
Date Posted: July 09, 2005 at 7:50 PM
A member of a different forum sent me a picture of the connector where the VSS signal terminates on a non-navi car. I think it's in the ECU connector, at pin 26. I don't know how to upload a picture here so if you send me your email address (Or tell me how to upload the pic), I'll be happy to share it with you.
Thanks.
Posted By: eschamp
Date Posted: July 09, 2005 at 8:01 PM
Here's the picture.
posted_image
Posted By: teke0611
Date Posted: July 10, 2005 at 11:00 PM
According to the Honda diagram, E26 is only in the harness on navigation-equipped cars.  It is a VSS output from the main computer.  I haven't tried, but it is possible that the ecu in a non-navi car will still send the pulse to this pin.
Here's a link to a PDF for a 2005 Accord ecu at this pin, which has the same pinout.  https://www.billshonda.com/reference/2005_Accord_AC0305023003A.pdf
Maybe that helps a bit.  ?
Posted By: eschamp
Date Posted: July 11, 2005 at 11:19 AM
That's a much better diagram than what's in the Acura service manual!
Aha! I discovered the pinout diagram on page 11-25 (the Fuel and Emissions section -- silly me was looking at Electrical!). And it says that pin 26 of connector E is VSS OUT (with no notes about nav or non-nav! :-)
Thanks.
Posted By: teke0611
Date Posted: July 23, 2005 at 4:27 PM
Hope that helped out a little.  Best luck!
