Wire Diagram for ’98 Galant
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58473
Printed Date: April 19, 2026 at 7:02 AM
Topic: Wire Diagram for ’98 Galant
Posted By: nortiva
Subject: Wire Diagram for ’98 Galant
Date Posted: June 27, 2005 at 10:19 PM
Hey I need a wire diagram for a 98 mit. galant, i'm installing a magnum auto security and i'm kinda not sure what i'm doing so any help would be great too
thanks a lot
Posted By: thepencil
Date Posted: June 28, 2005 at 8:49 AM
DIRECTWIRE™ WIRING INFORMATION - MITSUBISHI / GALANT / 1998 / Security
12volts red (larger of 2)   +   ignition harness
Starter BLACK / YELLOW   +   ignition harness
Ignition BLACK/ white   +   ignition harness
Power Lock GREEN / WHITE   -   brown & blue plug be-
Power Unlock RED / green   -    hind driver dash speaker
Lock Motor blue/black   5wi driver window switch in door
Unlock Motor blue/red   5wi driver window switch in door
Disarm Defeat blue/red   5wi driver rear door harness
Parking Lights+ GREEN / WHITE   +   behind fuse box, lower harness
Parking Lights- GREEN/ orange   -   headlight switch
Hazards same as turn signals
Turn Signal(L) GREEN/ blue   +   steering column
Turn Signal(R) GREEN/ YELLOW   +   steering column
Door Trigger GREEN/ red   -   behind fuse box, lower harness
Dome Supervision use door trigger
Trunk/Hatch Pin GREEN/ black   -   light in trunk
Notes: On vehicles with factory alarm, the trunk pin is BROWN / blue (-) in the 16 pin plug at the ETACS ECU.
The ETACS (Electronic Timer Alarm Control System) ECU is attached to the fuse box in the driver kick panel.
Hood Pin brown   -   16 pin plug at ETACS ECU
Notes: The ETACS (Electronic Timer Alarm Control System) ECU is attached to the fuse box in the driver kick panel.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm yellow   -   16 pin plug at ETACS ECU
Factory Alarm Disarm yellow/white   -   16 pin plug at ETACS ECU
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   ignition coil pack
Horn Trigger GREEN/ red to lt. green   -   steering column
Notes: The horn trigger functions only with the blue/white second accessory wire energized.
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: nortiva
Date Posted: June 28, 2005 at 10:21 AM
thanks a lot
Date Posted: June 28, 2005 at 12:53 PM
You are more than welcome.
