1997 gmc jimmy
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62297
Printed Date: April 30, 2026 at 1:59 PM
Topic: 1997 gmc jimmy
Posted By: galantin
Subject: 1997 gmc jimmy
Date Posted: September 06, 2005 at 6:37 PM
need remote start/alarm wiring colors/locations, thanks
Posted By: chungo
Date Posted: September 06, 2005 at 7:16 PM
| 12volts | red | + | ignition harness | | Starter | purple or yellow | + | ignition harness | | Second Starter | | | | | Ignition | pink | + | ignition harness | | Second Ignition | white or pink/white | + | ignition harness | | Third Ignition | | | | | Accessory | orange | + | ignition harness | | Second Accessory | | | | | Keysense | | | | | Power Lock | lt. blue | + | either kick panel | | Notes: Also found at the TRW keyless entry module mounted to the under dash panel on drivers side. With the module unplugged, the drivers door lock will no longer function. | | Power Unlock | white | + | either kick panel | | Notes: Also found at the TRW keyless entry module mounted to the under dash panel on drivers side. With the module unplugged, the drivers door lock will no longer function. | | Lock Motor | gray | | drivers kick panel | | Unlock Motor | tan | | drivers kick panel | | Parking Lights+ | brown | | switch or rear harness | | Parking Lights- | | | | | Hazards | | | | | Turn Signal(L) | | | | | Turn Signal(R) | | | | | Reverse Light | | | | | Door Trigger | white | - | keyless module | Notes: Also found at the TRW keyless entry module mounted to the under dash panel on drivers side. With the module unplugged, the drivers door lock will no longer function.
This wire cathes all doors, but reads the delay. To keep the alarm from reading the delay, place a diode in-line on the white door trigger wire with the anode towards the keyless module. Attach your door trigger wire to the cathode side of the diode. On non-keyless models the is a module with 5 wires located where the keyless normally resides. The white wire there catches only the front two doors. To catch the rear doors use the white wire at the drivers side rear pin switch. | | Dome Supervision | use door trigger | | | | Trunk/Hatch Pin | tied in with doors | | | | Hood Pin | | | | | Trunk/Hatch Release | BLACK/ white | + | switch or keyless | | Notes: Also found at the TRW keyless entry module mounted to the under dash panel on drivers side. With the module unplugged, the drivers door lock will no longer function. | | Power Sliding Door | | | | | Factory Alarm Arm | | | | | Factory Alarm Disarm | | | | | Disarm No Unlock | | | | | Tachometer | white | AC | ECM | | Notes: The ECM is located on the passenger inner fender well. Located the white wire in a black plug labeled *white*. | | Wait to start | | | | | Brake Wire | white | + | at brake pedal switch | | Parking Brake | | | | | Horn Trigger | black | - | steering column | | Memory Seat 1 | | | | | Memory Seat 2 | | | | | Memory Seat 3 | | | |
| Interface Module: | Category: Immobilizer Bypass | Required: No | Type: N/A | | Part #: N/A | | Notes: |
Posted By: galantin
Date Posted: September 08, 2005 at 9:09 PM
thanks
