Tachometer, 1999 Ford F-150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62709
Printed Date: April 03, 2026 at 9:13 PM
Topic: Tachometer, 1999 Ford F-150
Posted By: glacious
Subject: Tachometer, 1999 Ford F-150
Date Posted: September 14, 2005 at 10:13 PM
I have a 1999 Ford F-150 to which I wanna install a tachometer. I have found one that I want, and at a good price. The problem is, that I e-mailed the company, asking if I would need any other accesories, or if it would even work on my vehicle. HE said that the possibility if it working, were 50-50. He said that It would work, but as to what nature of acuracy it would read, he wasn't really sure. My question is, has anyone installed an aftermarket tach on a Ford truck, or any vehicle for that matter, and how hard was it, did you need any additional accesories, and finally, did it work well enough? I am very intrested in buying the thing, and trying to install it, but I don't wanna waste all that money, on something that isn't going to even read right. So please if you have any suggestions, I would really appreciate them~~
JP
Posted By: blazeronspokes
Date Posted: September 16, 2005 at 9:55 AM
Tach wire: on the 4.2L it is a dk. blue/lt. green at the coil pack on top of the motor. On the 4.6L it is a pink/white in a 3 pin plug at the front of the motor below the air intake and next to the fan. On the 5.4L it is a lt. GREEN / WHITE at the coil on the passenger side of the motor between the fuel injectors.
Posted By: glacious
Date Posted: September 16, 2005 at 3:57 PM
Thanks Blazeronspokes!! Ok, sounds simple enough, I think. So do i just tap into the dk blue/lt green wire with a lead from the Tach and then ground the tach? Is it really that simple of an install???
JP
