1981 Fleetwood remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63042
Printed Date: April 19, 2026 at 7:02 AM
Topic: 1981 Fleetwood remote start
Posted By: DOUBBLEOUGHT
Subject: 1981 Fleetwood remote start
Date Posted: September 21, 2005 at 7:53 PM
Hey guys, I am having a little trouble installing a remote start (autopage 855lcd) any help on schematics or wiring info would be great.....
Posted By: thepencil
Date Posted: September 22, 2005 at 11:29 AM
1984 is as far back as I can go on the infomation pertainning to your vehicle.
DIRECTWIRE™ WIRING INFORMATION - CADILLAC / FLEETWOOD / 1984 / Remote Start
12volts red    +   ignition harness
Starter purple    +   ignition harness
Second Starter
Ignition pink    +   ignition harness
Second Ignition
Third Ignition
Accessory orange    +   ignition harness
Second Accessory
Keysense
Power Lock lt. blue    +   either kick
Power Unlock black or blk/blu    +   either kick
Lock Motor
Unlock Motor
Parking Lights+ brown      lt switch, running brd
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white or lt blue    -   pin sw,lt sw, ctsy lt
Notes: Light blue at pinswitch or at pin J of theft deterrent module, above gas pedal. Light blue not affected by domelight delay.
Dome Supervision
Trunk/Hatch Pin gray    -   tr lock relay
Notes: Relay under dash, passenger side, with door lock relays.
Hood Pin
Trunk/Hatch Release black    +   release switch
Power Sliding Door
Factory Alarm Arm lock w/door open
Factory Alarm Disarm light green    -   Dkp or pin H, TDM
Disarm No Unlock
Tachometer PURPLE / white   AC   distributor/coil pack
Notes: Some coil packs rear of engine above transaxle.
Wait to start
Brake Wire white    +   brake switch
Parking Brake
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.posted_image
