04 Silverado Back up sensor install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63996
Printed Date: April 03, 2026 at 5:54 PM
Topic: 04 Silverado Back up sensor install
Posted By: KWshrider
Subject: 04 Silverado Back up sensor install
Date Posted: October 07, 2005 at 12:25 PM
To All,  I wasn't sure where one of these would fit in but am installing an aftermarket parking assist sensor system on an '04 silverado crew cab and am looking for the reverse light wire and brake light wire up under the dash.
This system has four sensors in the back and two up front which engage when the vehicle is put in reverse or when the brakes are applied and changes pitch as the vehicle gets closer to an object when parking in close areas.  Any assistance anyone can send my way would be greatly appreciated
V/R,
Steve
Steve R
Key West, FL
Posted By: KarTuneMan
Date Posted: October 07, 2005 at 1:54 PM
On the rear of the vehicle there should be a tow hook up. you can get the "reverse wire" in this harness. Or if you want you can get it niside the tail light at the bulb. If your gonna tow a truck youll want to install a toggle switch. if not it can all be wired at the rear of the truck. The reverse wire is 12v and the other hook up is ground....easy.  I would go inside the tail light....fewer wires to test
Posted By: Velocity Motors
Date Posted: October 07, 2005 at 3:16 PM
If this is a Rostra back up unit, all you need to do is hook up the reverse lights for the module  which is RED at the ECU PIN13 . ECU IS TO THE FAR RIGHT BEHIND GLOVE BOX
