1993 Remote start wont start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6427
Printed Date: May 22, 2026 at 6:43 AM
Topic: 1993 Remote start wont start
Posted By: roryemmans
Subject: 1993 Remote start wont start
Date Posted: December 09, 2002 at 3:03 PM
I have a 1993 Chevrolet Suburban and am in ther process of installing a remote start with no luck.  I can get the vehicle to crank but it will not start.  I have two new Design Tech remote starters model 26727 & 26327 with the same results.  I suspect it is something to do with the ignition wires but am not positive and have read the install instructions and contacted their tech support a few times with no luck.  All wires tested out at 12 volts in the correct key position. I am assuming that the install instructions are missing something that I am not aware of. I have listed the wiring information below for my vehicle.  If anybody has any information that could help me it would be greatly appreciated.
Remote Starter  Wiring Colors and Notes
Function
DTI Color
Vehicle  Color
Location
Start:
Yellow
YELLOW OR VIOLET
IGNITION SWITCH HARNESS **
Ignition  #1:
Blue
PINK
Ignition #2:
Green
ORANGE
IGNITION SWITCH HARNESS (HEAT/AC) ***
Ignition  #3:
Wht/Blk
N/A
Accessory:
White
BROWN
IGNITION SWITCH HARNESS (WIPERS/RADIO)
Brake  Light:
Orange
WHITE
(+) SWITCH ON BRAKE PEDAL BRACKET
Tach  Signal:
Green
WHITE
AT DISTRIBUTOR *
Parking Lights:
Yellow
BROWN
(+) AT HEADLIGHT SWITCH
Headlights:
Yellow
YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm  Disarm:
Brn/Wht
N/A
OEM Alarm  Arm:
n/a
N/A
Diesel  Glow Plug:
RED / Black
Clutch  Bypass Wire:
n/a
Notes:
 * WHITE Wire At Ignition Coil Or At Tach Test Connector (2 Pin Plug) Taped To Harness Next To Distributor Can Also Be Used For Tach Signal. ** See Note #300 - GM Rear Wheel Drive Vehicles *** See Note #216 - High Current Ignition Wires Diagram.
Chevrolet
Suburban
1992-1994
Alarm and Keyless  Entry Wiring Colors and Notes
Function
DTI Color
Vehicle  Color
Location
Constant  +12 Volts:
Red
RED AND RED
Starter  Kill:
Vlt or Wht
YELLOW OR VIOLET
Ignition  +12 Volts:
Orange
PINK
Dome  Lights/Superv:
Brown
BLACK/ ORANGE
(-) AT PIN SWITCH
OEM Horn:
Blue
BLACK (-)
STEERING COLUMN HARNESS OR HORN RELAY
Power  Lock:
Wht/Red
LIGHT BLUE
DRIVER'S KICK PANEL IN CAVITY OR
Power  Unlock:
Yel/Red
BLACK
RELAYS BESIDE GAS PEDAL ****
Trunk  Release:
Grn/Wht
BROWN (+)
RELEASE SW.(REAR WINDOW RELEASE)
Alarm  Input Wire:
R/W or Gy/Bk
BLACK/ ORANGE
(-) AT PIN SWITCH
Notes:
**** See Note #202 - Positive Pulse Door Lock Diagram.
DesignTech  International, Inc.
Tel: (703)  866-2000 Fax: (703) 866-2001
©2002  All Rights Reserved
7955 Cameron  Brown Court
Springfield, Virginia 22153 USA
1-800-DESIGNTECH
(1-800-337-4468)
www.designtech-intl.com
DesignTech disclaims any liability or responsibility arising out of any inaccuracies of this information or use of this
information for installations or otherwise. Please verify all wiring for accuracy prior to making any connections.
Thanks in advance
Rory Emmans
Posted By: Velocity Motors
Date Posted: December 09, 2002 at 3:16 PM
Use your voltmeter to probe the wires behind the key. There will be one wire
(usually a large diameter wire) which you have not hooked up to which is hot in the
run and crank position, which is the missing wire. Simply connect one of our IGN1
or IGN2 wires to this wire. If you already are using both of these wires (IGN1 and
IGN2) – you may find that one of them is an Accessory wire which should have
been powered up by the white Accessory wire. If not, and you need both of these
for ignition – and yet still need the 3rd ignition wire – simply jumper this new wire
over to the AutoCommand®’s IGN1 or IGN2 wire. Or, use the transistor output of
IGN3, which is available on some models, and be sure to have this IGN3 output
drive a relay to power up your new ignition wire.
Date Posted: December 09, 2002 at 3:45 PM
Thanks for the quick response.  From everything I read I do not have a third IGN wire for a 1993 Suburban.  One guy from Design Tech told me to swap IGN 2 wire( from orange to Brown) and change the accessory wire from (Brown to orange) but I had the same results.  Do you know if the Ignition wiring diagram is correct for a 1993 Suburban Pink for IGN1 and  Orange for IGN2?
Thanks in advance
Rory Emmans
Date Posted: December 09, 2002 at 7:40 PM
This is what I have for the Burban:
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow or purple    |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |either door boot            |
|     POWER UNLOCK|BLACK/ red           |+  |either door boot            |
| PARKING LIGHTS +|brown               |   |headlight switch *1         |
|       HEADLIGHTS|yellow              |+  |headlight switch            |
|     DOOR TRIGGER|white               |-  |headlight switch            |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|TRNK/HTCH RELEASE|black               |+  |release switch              |
|       TACHOMETER|PURPLE / white *2     |   |ECM *3                      |
|      SPEED SENSE|green               |4  |ECM *3                      |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |steering column             |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |drivers door switch         |
|  RF WINDOW UP/DN|lt.blue - tan       |A  |drivers door or boot        |
|  LR WINDOW UP/DN|green - purple      |A  |drivers door or boot        |
|  RR WINDOW UP/DN|lt. grn - purple    |A  |drivers door or boot        |
Notes:
*1 Also found low in the drivers kick panel.  *2 Also found as white at the instrument cluster. For diesel tach, use white at the alternator or instrument cluster. Diesel wait to start wire is dk. blue (+) located at the instrument cluster.  *3 The ECM is located behind the glove box to the right side.
Posted By: donsmith249
Date Posted: December 11, 2002 at 10:43 AM
On the dash does the security light go off when trying to start, if not sounds like pass lock 2 is the problem.
Don Smith
Plano TX
Date Posted: December 11, 2002 at 10:47 AM
Also there is a second ign. wire that must be powered up when starting a thin gauge white wire, dei tech support to me on the 03 you must power up the brown and orange wires when remote starting.
Don Smith
Plano TX
Date Posted: December 11, 2002 at 11:13 AM
Sorry to wait so long to get back but i lost my HD on my PC and had to rebuild.  No security light on my 1993. No passlock on the 1993 suburban (started in 1995) from what little i know. I have IGN 1 (Blue) going to Pinkl, have IGN 2(green) wire going to the Orange and accessory (white) wire going to the brown per DEI instructions.
Thanks in advance
Rory Emmans
Date Posted: December 11, 2002 at 1:36 PM
Sorry was thinking 03'
Don Smith
Plano TX
Date Posted: December 16, 2002 at 10:30 AM
FYI it turns out the problems was in the connectors I was using.  I retermintaed these connections without connectiors and it works great.  Thanks for everbody's input
Rory
Thanks in advance
Rory Emmans
