Nissan Micra wiring coloring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64787
Printed Date: April 25, 2026 at 9:08 PM
Topic: Nissan Micra wiring coloring
Posted By: roklo
Subject: Nissan Micra wiring coloring
Date Posted: October 21, 2005 at 3:49 PM
Looking for information on wiring coloring of a Nissan Micra 1986
Thanks!
Posted By: thepencil
Date Posted: October 24, 2005 at 9:32 AM
Sorry that all what is avaiable.
DIRECTWIRE™ WIRING INFORMATION - NISSAN / MICRA (UK) / 1987 / Remote Start
12volts
Starter BLACK/ pink      ignition harness
Second Starter
Ignition BLACK/ red      ignition harness
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock
Power Unlock
Lock Motor
Unlock Motor
Parking Lights+ grn/yel & grn/red     under the steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      -   driver door switch
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Modules: Not Available
Be careful whose advice you buy, but be patient with those who supply it.posted_image
