2003 Ford Focus Se 4 Dr Alarm/RS/Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65959
Printed Date: April 18, 2026 at 2:17 PM
Topic: 2003 Ford Focus Se 4 Dr Alarm/RS/Stereo Wiring
Posted By: crash103k
Subject: 2003 Ford Focus Se 4 Dr Alarm/RS/Stereo Wiring
Date Posted: November 09, 2005 at 10:10 PM
i'm looking for the wiring diagram for a 2003 ford focus se 4 door
the alarm i'm installing is a viper 791xv
thanks in advance
Posted By: ziggyb222
Date Posted: November 10, 2005 at 7:25 AM
It is right on this site..look under general info and then vehicle wiring....just select year,make model..hope this helps
Posted By: joe_1
Date Posted: November 11, 2005 at 10:55 AM
ItemWire ColorPolarityWire Location
12Vred+ignition harness
STARTERgray/black+ignition harness
IGNITIONGREEN/ YELLOW+ignition harness
ACCESSORYyellow+ignition harness
SECOND ACCESSORYnone
TACHOMETERBLACK/ greenignition coil
POWER LOCKBLACK/ red-drivers kick panel
POWER UNLOCKBLACK / YELLOW-drivers kick panel
PARKING LIGHTS +orange / YELLOWheadlight switch
PARKING LIGHTS -
DOOR TRIGGERBLACK/ blue-low in drivers kick panel
HEADLIGHTSgrn/blu(L),grn/yel(H+steering column *3
WIPERSWHITE/ green+steering column
LF WINDOW UP/DNyellow - whiteAin drivers door at motor
RF WINDOW UP/DNyel/pur - wht/purAdrivers switch or kick panel
LR WINDOW UP/DNyel/blu - wht/bluAdrivers switch or kick panel
RR WINDOW UP/DNyellow - whiteAdrivers switch or kick panel
TRUNK/HATCH PINBLACK/ white-trunk light
HOOD PINBLACK / YELLOW *4-keyless module *1
TRUNK/HATCH RELEASEBLACK / YELLOW-switch or keyless module *1
FACTORY ALARM ARM
FACTORY ALARM DISARM
HORN TRIGGERBLACK/ blue-steering column
BRAKE WIRElt. GREEN/ red+brake switch *2
LOCK MOTORyellow/blackdrivers kick panel
UNLOCK MOTORWHITE/ blackdrivers kick panel
DISARM DEFEATWHITE/ blackpassengers kick panel
DISARM NO UNLOCK
DOME SUPERVISIONuse door trigger
SPEED SENSEWHITE/ greenradio
SUN ROOF OPEN/CLOSE
SUN ROOF LIMIT
LF SPEAKERwht/blk - gry/blkradio
RF SPEAKERwht/red - gry/redradio
LR SPEAKERwht/pur - gry/whtradio
RR SPEAKERwhite - grayradio
RADIO 12VORANGE / black (thick)+radio
RADIO GROUNDblk/yel & blk/grn-radio
RADIO SWITCHYELLOW /GREEN+radio
RADIO ILLUMINATEORANGE / black (thin)+radio
POWER ANTENNA
Notes:NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555S to bypass. *1 Keyless module is behind the glove box to the right. *2 To meter the brake wire, must turn ignition on. *3 Low beam at the headlight switch is GREEN/ red. *4 Only if equipped with factory alarm.
