Tach, 2005 hilux/tacoma
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68424
Printed Date: May 02, 2026 at 7:38 PM
Topic: Tach, 2005 hilux/tacoma
Posted By: jamie_christo
Subject: Tach, 2005 hilux/tacoma
Date Posted: December 15, 2005 at 3:30 AM
Gday, have a 2.7L 2005 Hilux or in US i think it is a Tacoma i am looking to wire up a new tachometer but cannot find the right wire, is it the black with red stripe? i cant seem to find a pulse with multimeter either, please help.
cheers, Jamie
Posted By: Velocity Motors
Date Posted: December 15, 2005 at 8:07 AM
The tach wire is BLACK/ WHITE at the ECM. On the 6 cylinder models, it is in the 2nd plug from the bottom, pin 1. On the 8 cylinder models, it is in the bottom plug, pin 5.
On the 6 cylinder models, you can also find this wire at the data link connector under the driver side dash.
The Hilux (Surf) is a 4Runner in North America.
------------- Jeff
Date Posted: December 15, 2005 at 8:08 AM
BTW, this information is for the gasoline engine not the turbo diesel engines.
------------- Jeff
Date Posted: December 16, 2005 at 5:58 PM
myne is the 4cyl but it should be the same?
Date Posted: December 16, 2005 at 6:22 PM
Yes it should be the same. If you can't find the wire at the ECM use an injector wire instead.
------------- Jeff
Date Posted: December 16, 2005 at 7:05 PM
where would you recomend taping power from? cigarette lighter?
Posted By: Mike M2
Date Posted: December 16, 2005 at 7:06 PM
I think the Hilux is like the old style Tacoma. Look for a light GREEN/ black at the data link connector under the dash. If it doesn't have one it should be at the instrument cluster....
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: gadjet478
Date Posted: January 04, 2006 at 3:16 AM
hey there it may be a bit late i'm in WA and have recently fitted a tacho to my lux. remove the instument cluster and behind it you will find a yellow plug, it has...
(+)acc power.
(+)ignition power.
and
(-)earth. use these for your power supply.
on the back of the instument cluster on the middle plug
you need to tap into the red wire with a white trace as your ignition pulse.
cheers hope to be of assistance.
gadjet.
Date Posted: January 04, 2006 at 3:38 PM
its good to find another aussie :> there is no info on the 2005 lux anywere lol, cheers for the info, Jamie
