2006 MX-5 Miata Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69647
Printed Date: April 05, 2026 at 11:05 PM
Topic: 2006 MX-5 Miata Wiring
Posted By: pauls
Subject: 2006 MX-5 Miata Wiring
Date Posted: December 31, 2005 at 8:12 AM
I'm having difficulty fing a battery powe lead in the left footwell. Any suggestions? The only one I have found is the brake light switch.
Posted By: MHARVEY
Date Posted: January 01, 2006 at 6:49 PM
SECURITY
Battery  WHITE/ RED  (+)  IGNITION SWITCH HARNESS
 Ignition 1  RED / BLACK  (+)  IGNITION SWITCH HARNESS
 Starter 1  WHITE/ BLACK  (+)  IGNITION SWITCH HARNESS
 All Door Trigger  WHITE/ RED  (-)  IN HARNESS IN DRIVERS KICKPANEL
 Trunk Trigger  RED / WHITE  (-)  AT LIGHT IN TRUNK
 Parking Lights  RED / BLACK  (+)  IN HARNESS IN DRIVERS KICKPANEL
REMOTE START
 Ignition 2  BLACK/ RED  (+)  IGNITION SWITCH HARNESS
 Accessory 1  GREEN/ RED  (+)  IGNITION SWITCH HARNESS
 Anti-Theft Type  UNIVERSAL IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Neutral Safety  VIOLET  (-)  AT MODULE ABOVE GAS PEDAL - PIN #18
 Tachometer  BROWN  (-)  AT MODULE ABOVE GAS PEDAL ON FIREWALL
 Speed Sense  BLACK/ WHITE  (AC)  IN HARNESS IN PASSENGER KICKPANEL
 Brake Lights  GREEN  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  RED / YELLOW  (+)  IN HARNESS IN DRIVERS KICKPANEL
DOOR LOCK
Power Unlock  RED / BLUE  (-)  AT DOORLOCK CONTROL MODULE NEAR STEERING COLUMN
 PowerLock  RED / BLUE  (-)  AT DOORLOCK CONTROL MODULE NEAR STEERING COLUMN
Headlights-Lo  BLACK/ BLUE  (+)  IGNITION SWITCH HARNESS
 Wipers-Lo  BLACK/ WHITE  (+)  IGNITION SWITCH HARNESS
