96 Altima amp wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69912
Printed Date: April 05, 2026 at 11:05 PM
Topic: 96 Altima amp wiring
Posted By: pendulum
Subject: 96 Altima amp wiring
Date Posted: January 03, 2006 at 1:26 AM
My friend has a 96 Altima, and the only place I can find to run the power for his amp is on passenger side of the firewall, behind the intake manifold. It's a real pain to get to, I burnt myself twice and I couldn't even get the wire through. Is there any better places to go through the firewall? If so, can you explain where?
Thanks in advance
Matt
Posted By: Hornshockey
Date Posted: January 03, 2006 at 11:13 AM
does the car have a manual transmission?
------------- Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Posted By: pendulum
Date Posted: January 03, 2006 at 3:59 PM
Automatic transmission, basic sound. No BOSE stuff.
Posted By: fingaz22
Date Posted: January 03, 2006 at 4:10 PM
maybe you should wait until the engine is cool?  ------------- JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
Date Posted: January 03, 2006 at 4:26 PM
in almost every car, there is a spot to the left of the brake booster reserved for a clutch linkage. That is usually a perfect place to drill a hole and pass wire through. My 97 camry has a spot that I used, even a plate spot welded over the hole that would be used for the clutch. I've never once seen a manual transmission in a camry, but the spot is still there. It's there on the Altima too.
Posted By: pendulum
Date Posted: January 04, 2006 at 2:45 PM
Thanks guys, I actually ended up just pushing the rubber grommet out from inside the car. Only problem now is that the amp won't turn on. I'm 100% sure it's wired properly, and it is getting power. I'm gonna try the amp in my car and I might end up returning it.
