02 Nissan Altima, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70454
Printed Date: April 03, 2026 at 1:24 PM
Topic: 02 Nissan Altima, remote start
Posted By: jeepwj
Subject: 02 Nissan Altima, remote start
Date Posted: January 10, 2006 at 8:22 AM
My information says both the Ignition wire and the starter wire in the harness are BLACK/ red. One of the two BLACK/ red wires is thicker diameter than the other.  Does anyone know which is which?
Thanks in advance.
2002 Nissan Altima
ItemWire ColorPolarityWire Location
12Vgreen+ignition harness
STARTERBLACK/ red+ignition harness
IGNITIONBLACK/ red+ignition harness
ACCESSORYred+ignition harness
SECOND ACCESSORYnone
TACHOMETERWHITE/ greenECM behind glove box *4
POWER LOCKpink *7-pin 37 @ BCM by fuse box
POWER UNLOCKbrown *7-pin 44 @ BCM by fuse box
PARKING LIGHTS +RED / bluedriver kick panel
PARKING LIGHTS -none
DOOR TRIGGER*2-BCM to right of fuse box
HEADLIGHTSblu (L), RED / yel (R)+IPDM E/R *1
WIPERSblu (L), blu/blk (H)-wiper motor
LF WINDOW UP/DNblu/red - blu/whtAdriver window switch
RF WINDOW UP/DNgreen - yellow *6Adriver kick panel
LR WINDOW UP/DNpurple - blueAdriver kick panel
RR WINDOW UP/DNRED / yel - yel/blkAdriver kick panel
TRUNK/HATCH PINPURPLE / white-pin 18 @ BCM by fuse box
HOOD PINyellow/black-hood pin switch
TRUNK/HATCH RELEASERED / blk or blu/red-pin 76 @ BCM by fuse box
FACTORY ALARM ARMpink/blue *3-driver switch in door
FACTORY ALARM DISARMWHITE/ blue *3-driver switch in door
HORN TRIGGERGREEN / WHITE-steering column
BRAKE WIRERED / green+brake pedal switch
LOCK MOTORyellow/redpin 30 @ BCM by fuse box
UNLOCK MOTORGREEN / WHITEpin 23 @ BCM by fuse box
DISARM DEFEATGREEN/ redpin 31 @ BCM by fuse box
DISARM NO UNLOCKnone
DOME SUPERVISIONcomes on with unlock
SPEED SENSEblue / YELLOW *58pin 9 @ instrument cluster
SUN ROOF OPEN/CLOSEnot recommended
SUN ROOF LIMITnone
LF SPEAKERblu/wht - blu/redradio or amp under rear deck
RF SPEAKERwht/blk - blu/blkradio or amp under rear deck
LR SPEAKERgrn/yel - blk/yelradio or amp under rear deck
RR SPEAKERblue - redradio or amp under rear deck
RADIO 12VYELLOW /GREEN+radio
RADIO GROUND
RADIO SWITCHpurple+radio
RADIO ILLUMINATERED / blue+radio
POWER ANTENNAgreen+radio
Notes:NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 The IPDM E/R (Intelligent Power Distribution Module Engine Room) is under the hood behind the passenger side headlight. *2 The LF door trigger is lt. blue in pin 14, RF door is pink/blue in pin 10, and the LR and RR door is RED / black in pin 11. *3 Meter these wires while turning the key in the driver door key cylinder. These wires will also lock and unlock the doors. Unlock requires a double pulse. *4 On the 4 cylinder vehicles it is in pin 36, and on the 6 cylinder it is in pin 34. Can also go to one of the ignition coils and use the wire that is NOT red or black. *5 If vehicle has the midline audio system or BOSE, the vehicle speed sense is also found at the radio, it is pink. *6 If vehicle has auto up/down on the front passenger window switch then must go into the passenger door and use blue for up and GREEN/ black for down. *7 These wires are only available on vehicle with left front only power window anti-pinch system. On vehicles with left AND right front power window anti-pinch system, use the factory alarm arm and disarm wires for door locks.
Posted By: KarTuneMan
Date Posted: January 10, 2006 at 9:32 AM
Ign. is the small one!
Posted By: jeepwj
Date Posted: January 12, 2006 at 3:55 PM
I am installing an Autocommand remote starter with a DEI 556U Bypass. I finished connecting the wires and tested it out. The car just cranks and cranks and cranks but wont start. Any ideas?
Posted By: jeepwj
Date Posted: January 13, 2006 at 12:41 PM
Hi, I have a 2002 Nissan Altima and when I remote start it the car starts and runs for 10 seconds or so then shuts off. If i put my key in the ignition and turn it to Run during these ten seconds it will remain running. I do not have a tach wire hooked up. I am using an autocommand remote starter and a DEI 556U Bypass. The bypass wires are connected as follows. Red- 12v Black- ground Blue- Status Output from Remote start module.
Any Ideas? Should I be looking at the bypass or something else?
