2005 Focus Alarm/Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70682
Printed Date: April 03, 2026 at 12:35 AM
Topic: 2005 Focus Alarm/Remote Start
Posted By: mrplowjr_ez_v
Subject: 2005 Focus Alarm/Remote Start
Date Posted: January 13, 2006 at 1:56 PM
Looking for wiring information for a 2005 Ford Focus.
Posted By: mobilecustoms
Date Posted: January 13, 2006 at 2:11 PM
12 VOLT CONSTANT RED (+) IGNITION SWITCH HARNESS
STARTER GRAY/BLACK (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 GREEN/ YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 N/A
KEYSENSE RED / BLACK (-) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) ORANGE / YELLOW (+) @ HEADLIGHT SWITCH or GEM, TAN Plug, Pin 14, See NOTE *4
POWER LOCK BLACK/ RED (TYPE B) IN DRIVERS KICK PANEL or GEM, GRAY Plug, Pin 15, See NOTE *4
POWER UNLOCK BLACK / YELLOW (TYPE B) IN DRIVERS KICK PANEL or GRAY Plug, Pin 21, See NOTE *4
LOCK MOTOR WIRE YELLOW/BLACK (+) IN DRIVERS KICK PANEL
DOOR TRIGGER See NOTE *1 @ GEM, See NOTE *4 29358_FOCUS_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
DOMELIGHT SUPERVISION BLACK/ BLUE (-) @ GEM, GREY Plug, Pin 3, See NOTE *4
TRUNK RELEASE BLACK / YELLOW (-) @ TRUNK RELEASE SWITCH
SLIDING POWER DOOR N/A
HORN BLACK/ BLUE (-) or BLACK/ GREEN (-) @ STEERING COLUMN HARNESS or GEM, BROWN Plug, Pin 14
TACH BLACK/ GREEN or BLACK/ ORANGE @ IGNITON COIL
WAIT TO START LIGHT N/A
BRAKE GREEN/ RED (+) @ GEM, TAN Plug, Pin 9, See NOTE *4
FACTORY ALARM DISARM BLACK/ WHITE (-) @ GEM, GRAY Plug, Pin 14, See NOTE *4
ANTI-THEFT FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 This vehicle has (4) door trigger wires, the DRIVERS DOOR is a YELLOW/BLACK (-) in a TAN Plug, Pin 22, the PASSENGER DOOR is a BLACK/ BLUE (-) TAN Plug, Pin 21, the DRIVERS REAR DOOR is a BLACK/ ORANGE (-) in a WHITE Plug, Pin 15 and the PASSENGER REAR DOOR is a BLACK/ GREEN (-) in a GRAY Plug, Pin 15. When connecting to an ALARM SYSTEM use all 4 DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM
NOTE *2 The IGNITION SWITCH MUST be turned on before the Brake wire will test properly.
NOTE *3 The FACTORY KEYLESS ENTRY Module (if so equipped) is located behind and to the right of the GLOVE BOX.
NOTE *4 The GEM (Generic Electronic Module) is located above the PASSENGER KICK PANEL.
