01 Dodge Dakota alarm wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71666
Printed Date: April 02, 2026 at 4:25 PM
Topic: 01 Dodge Dakota alarm wiring
Posted By: preludeofdesire
Subject: 01 Dodge Dakota alarm wiring
Date Posted: January 28, 2006 at 6:54 AM
I am looking for the wires needed to install an alarm on my 01 Dodge Dakota.  It will be just the alarm for now cause I don't have power locks.  I might add on but as of right now I don't have it.  If anyone can help I would apreciate it.
Posted By: notoriouswill
Date Posted: January 29, 2006 at 1:33 PM
12volts pnk/blk & RED / lt blu   +  ignition harness
Starter yellow   +  ignition harness
Ignition blue   +  ignition harness
Power Lock WHITE/ green  -  conn. 2, pin 10 @ CTM
Notes: Lock is negative trigger thru a 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
The Central Timer Module is in the driver kick panel.
Power Unlock same wire
Lock Motor ORANGE / black    conn. 2, pin 4 @ CTM
Notes: The Central Timer Module is in the driver kick panel.
Unlock Motor blue (4 dr only)    conn. 2, pin 6 @ CTM
Notes: The 2 door models do not have progressive unlock on the factory keyless.
Disarm Defeat pink/black    conn. 2, pin 5 @ CTM
Parking Lights+ BLACK / YELLOW    headlight switch
Parking Lights- RED / yellow    conn. 1, pin 4 @ CTM
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger    -  CTM
Notes: The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears on the 4dr) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information.
Dome Supervision use door trigger
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm lt. GREEN/ orange  -  conn. 2, pin 14 @ CTM
Notes: Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. This wire will also lock the doors, and it will unlock with a double pulse.
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer     ignition coil
Notes: On the 2.5L/3.9L/5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wires that is NOT GREEN/ orange at one of the coils.
Horn Trigger BLACK/ red   -  steering column or CTM
1 Memphis Mojo 15
1 Memphis 4000 watt amp
1 Memphis 75watt 4 channel amp
2 Memphis 6.5" MSQ's
posted_image
