Door Locks on 95 Grand am
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7278
Printed Date: April 19, 2026 at 5:57 AM
Topic: Door Locks on 95 Grand am
Posted By: NextelOnline123
Subject: Door Locks on 95 Grand am
Date Posted: December 28, 2002 at 2:26 PM
I need to know what type of door locks or on this car. Thanks alot
Posted By: Velocity Motors
Date Posted: December 28, 2002 at 3:00 PM
POWER LOCK|lt. blue            | +  |         gray conn R of e-brake *3   |
POWER UNLOCK|white         | +  |         gray conn R of e-brake *3   |
Also found at door lock relays, drivers underdash left of steering column. This is a (+) type B system
Date Posted: December 28, 2002 at 10:38 PM
So I can hook up the outputs from my keyless module to these wires without relays. I am using a dei 710t
Date Posted: December 28, 2002 at 11:10 PM
The 710T states that you do not need relays for this as they have internal relays that alternate polarity. Atach the GREEN wire from H2 --------->WHITE wire on GA and the BLUE wire from H2 --------------> LIGHT BLUE wire on the GA. If nothing happens when you do this ( the door locks do not actuate ) then you will need relays because the (+) current may not be enough to trigger the Pontiac's locking circuit. If this is the case use the above wires from the H2 and hook it up to 2 relays like it says in the POSITIVE INPUT-----------> POSITIVE OUTPUT diagram in the link below:
https://www.velocitymotorsport.com/install_notes/Converting_Outputs.jpg
