Audi A6 Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73518
Printed Date: March 31, 2026 at 1:41 PM
Topic: Audi A6 Wiring
Posted By: malharvey
Subject: Audi A6 Wiring
Date Posted: February 26, 2006 at 4:02 AM
Hello,
I have just recently joined and am looking for any wiring information/diagrams for my Audi A6 2.5 TDI (2000)
Regards,
Mal
Posted By: spookiestylez
Date Posted: March 04, 2006 at 7:55 PM
12volts red   +  ignition harness
Starter RED / black   +  ignition harness
Second Starter blue   +  ignition harness
Ignition black   +  ignition harness
Second Ignition
Third Ignition
Accessory yellow/black   +  ignition harness
Second Accessory
Keysense
Power Lock GREEN/ blue   -  C3, pin 12, keyless modul
Notes: The keyless module is under the driver side floor mat in front of the seat.
Unlock requires a double pulse. Ignition locks will cause the door lock switch and the interior lights not to work while driving, be sure to turn it off.
Power Unlock brn/yel or brn/gry   -  C3, pin 6, keyless module
Notes: Unlock requires a double pulse. Ignition locks will cause the door lock switch and the interior lights not to work while driving, be sure to turn it off.
Lock Motor
Unlock Motor
Parking Lights+     headlight switch
Notes: Vehicles with DRL use GREEN/ gray at the switch, and must use relay to isolate the switch side to prevent backfeed to the ignition. Vehicles without DRL use GREEN/ black and GREEN/ red at the switch.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger    -  keyless module
Notes: Drivers door trigger is GREEN/ YELLOW in Conn. 5, pin 1, front passenger door is RED / gray in C5, pin 10, left rear door is BLACK/ red in C5, pin 12, and right rear door is BLACK/ purple in C5, pin 14.
Dome Supervision comes on with unlock
Trunk/Hatch Pin
Hood Pin gray/red   -  C3, pin 10, keyless modul
Trunk/Hatch Release PURPLE / green   +  release switch
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer     ignition coils
Notes: For tach use gray / YELLOW, GREEN / WHITE, or GREEN/ gray at the coil pack on the front of the motor.
Wait to start
Brake Wire RED / black   +  brake pedal switch
Parking Brake
Horn Trigger BLACK / YELLOW   +  horn relay, driver side dash
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
RTFM
