2002 cavalier stereo/airbag
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7370
Printed Date: April 18, 2026 at 10:21 PM
Topic: 2002 cavalier stereo/airbag
Posted By: shane24
Subject: 2002 cavalier stereo/airbag
Date Posted: December 30, 2002 at 9:42 AM
   My question concerns installing a stereo in a 2002 cavalier that has the airbag wired straight to the factory radio. If at all posible I would like to know any alternative routes (i.e. ignition wires from steering column ect.) and any useful diagrams would be greatly appreciated. thank you.
Shane D. Spetnagel
Posted By: Velocity Motors
Date Posted: December 30, 2002 at 10:04 AM
The air bag is not wired straight to the radio rather the air bag reset is attached to the radio. If you take out the radio, you have the air bag light stay on the dash. Metra makes a harness that will add an aftermarket CD player to the stock wiring and you still get rid of the OEM deck. Look here:
https://metra.victorytechnologies.com/press_releases/innovations_archive_092402.asp#1
Posted By: pipes
Date Posted: February 10, 2003 at 1:50 AM
It is all lies! You can remove the factory stereo without problems, I have hundreds of people to back me up. All that happens is your door chimes stop working.
Posted By: BNLUIS
Date Posted: February 10, 2003 at 9:51 AM
That's true I just did a 2002 Cavalier last week. Last week I did one with no problem at all. The door chime stop working. It no longer chimes if lights are on, door open, trunk open, or the key is in the ignition.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: ggrizzle
Date Posted: February 19, 2003 at 6:49 PM
I have an 02 cavalier. I changed out the factory deck. I bought the wire harness to relocate the factory radio. I installed the aftermarket deck,ran the wire to the trunk and mounted the factory in the trunk. After everything was done and working fine. I unplugged the harness to the factory deck and left it off for a couple of days. The only thing that was missing was the door chime, like when you leave your lights on and open the drivers door. Other than that it does not hurt anything.
G.G.
Posted By: mike swanson
Date Posted: March 03, 2003 at 7:22 PM
they say the same for the sunfire ,but i had no probs, they lost door chime and the air bag light didnt stay on.
i even asked the dealer and the said its fine
Posted By: esmith69
Date Posted: March 03, 2003 at 7:32 PM
A couple of good links I've referenced in the past that deal with GM's class 2 wiring BSposted_image:
https://members.shaw.ca/johnz24/howto/2kaudio.html
https://www.bestkits.com/bk_2004t.asp
https://www.bestkits.com/Class2_BHA2004T.PDF
