2001 Toyota Tundra Remote Starter Keyless Entry Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75687
Printed Date: May 12, 2026 at 12:02 PM
Topic: 2001 Toyota Tundra Remote Starter Keyless Entry Wiring
Posted By: c kat
Subject: 2001 Toyota Tundra Remote Starter Keyless Entry Wiring
Date Posted: April 04, 2006 at 4:52 PM
have a 2001 toyota tundra looking for inf. on installing remote starter keyless entry  system wiring diagrams etc. truck has power locks thank you
cromwell
Posted By: mo12v
Date Posted: April 04, 2006 at 7:15 PM
Constant 12 voltsWHITE/ RED & WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterGREEN/ BLACKIGNITION SWITCH HARNESS
Dome LightBLACK/ WHITE (-)9 PIN CONN DRIVER SIDE JUNCTION BLOCK
Trunk Pin SwitchN/A
Parking LampGREEN (+)12 PIN CONN DRIVER JUNCTION BLOCK
Power LockWHITE/ GREEN12 PIN CONNECTOR IN
Power UnlockRED / YELLOWDRIVER KICK PANEL *
* Child Safety Lock - RED / BLUE (-) In Same Connector As Door Locks.
Child Safety locks
Accessories
Window UpD\ LIGHT GREEN P\ RED / BLACK @ MAIN SWITCH
Window DownR/ BLUE / YELLOW S/ RED / GREEN
Ign Key WarnPINK/BLACK (-)STEERING COLUMN HARNESS
Trunk ReleaseN/A
OEM HornGREEN/ RED (-)STEERING COLUMN HARNESS *
HeadlightsGREEN/ YELLOW (-)AT HEADLIGHT SWITCH *
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
* Located In 4 Pin Square Connector On Rear Of Junction Block In Behind Driver Lower Dash.
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalBLUE/WHITETOP REAR OF ENGINE (8 CYL) *
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL **
Reverse LightRED / BLACK (+)BACK-UP RELAY BOTTOM LEFT OF J/B
Rear Window DefrostN/A
* 6 Cylinder - BLUE At ECM Behind Passenger Dash. ** Also Located in 13 Pin Connector Left Side Of Driver Junction Block.
MO
