2001 Maxima Accessory Wire 4 A/C
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76015
Printed Date: May 11, 2026 at 11:47 PM
Topic: 2001 Maxima Accessory Wire 4 A/C
Posted By: t0mmyr
Subject: 2001 Maxima Accessory Wire 4 A/C
Date Posted: April 10, 2006 at 3:37 PM
I couldn't find  the RED / yellow wire in my harness for ACCESSORY listed here: https://www.the12volt.com/installbay/forum_posts.asp?tid=5857
when I wired in my 791xv, so I wired the alarms accessory output to accessory2 which is WHITE/ blue, well now that I have remote start installed, everything comes on ok, the radio and lights, EXCEPT my heater or A/C, it will only kick on once I put the key into my ignition and turn it to on, so I must have missed the right wire, that was one of the main purposes for remote start so that my car would be nice and cool on a hot summer day or nice and warm on a cold winter night, does anyone know which wire is the accessory wire for my 2001 Nissan Maxima GXE's HVAC?  and should I just also solder that to my existing WHITE/ blue(nissan harness) + viper accessory wire or disconnect the WHITE/ blue (nissan harness) and connect it to the new one you guys tell me is?
Posted By: xscash
Date Posted: April 14, 2006 at 8:24 PM
ok, remote start the vehicle....then test the wires in the ign harness...one of these wires will not show power...then turn your key. the wire that powers up should be your missing acc wire. now you should use a relay to power this extra wire.
xs
expandable sound
south of boston
Posted By: t0mmyr
Date Posted: April 14, 2006 at 8:52 PM
sounds good, i will test this weekend, could you please tell me which kind of relay i need to wire up? which diagram is the best so that it can be powered?
