2002 Dodge Dakota Ext Cab
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=769
Printed Date: April 19, 2026 at 8:40 AM
Topic: 2002 Dodge Dakota Ext Cab
Posted By: Mr Gadget256
Subject: 2002 Dodge Dakota Ext Cab
Date Posted: May 14, 2002 at 11:05 AM
Looking for Security/Stereo harness wires for the standard keyless entry and the upgraded Cassette/CD player with CD changer control and the Infinity speakers. Thanks
Posted By: Velocity Motors
Date Posted: May 14, 2002 at 6:17 PM
Go to https://www.metra.com for harnesses. If you are looking to upgrade to a different aftermarket deck go to Metra. Other wise please post why you need the harnesses so we can help you better.
Date Posted: May 14, 2002 at 10:05 PM
Jeff,
I just got a 02 Dakota with the keyless entry and I have bought a couple of alarm(s) and parts and want to integrate them into the factory system.  I went to Metra but all I found was what looked like a software company.
1. I'm looking for the 02 Dakota wires/colors on the factory keyless entry.
2. Also the stereo info because I might be able to use the amp on line from the stock radio as a passive starter interupt mechanism. (If the radio is off, the truck won't start) But I don't know if the stereo has it and don't want to rip up the dash just to look if someone already has the info.
Thanks, Mike
Date Posted: May 15, 2002 at 8:40 PM
Dodge
Dakota
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
DK. BLUE / YELLOW OR YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
DK. BLUE
Ignition #2:
GREEN/ RED
Ignition  #3:
N/A
Accessory:
BLACK/ ORANGE & GREEN
Brake  Light:
WHITE/ TAN
AT SWTICH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK/ GRAY
AT IGNITION COIL OR AT PCM
Parking Lights:
BLACK / YELLOW (+)
AT HEADLIGHT SWITCH
Headlights:
LT. GREEN/ ORANGE (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
LT.GREEN/ ORANGE
AT CENTRAL TIMER MODULE IN DRIVER'S KICK PANEL ****
OEM Alarm  Arm:
LT. GREEN/ ORANGE
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
 * If This Vehicle Has A Gray Ignition Key, Then It Is Equipped With A Transponder Immobilizer System.
Dodge
Dakota
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK & RED / LT. BLUE
Starter  Kill:
Ignition  +12 Volts:
DK. BLUE
Dome  Lights/Superv:
TAN (DRIVER'S) & TAN/RED (OTHERS)
(-) AT CENTRAL TIMER MODULE IN DRIVER'S KICK PANEL
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ GREEN
Power  Unlock:
WHITE/ GREEN
Trunk  Release:
N/A
Alarm  Input Wire:
Notes:
*** Single Wire Lock System, A Negative Trigger Through A 820 Ohm Resistor Will Lock Doors. A Negative Trigger Through A 330 Ohm Resistor Will Unlock Doors. ****  A Negative Trigger Through A 644 Ohm Resistor Will Arm And Lock The Doors. A Negative Trigger Through A 1565 Ohm Resistor Will Disarm The Alarm And A Second Pulse (Double) Will Unlock The Doors.
Sorry about the metra address .... it's https://www.metraonline.com and you can email them about the head unit question and they should be able to answer the question better for you.
