2000 impala ls Factory Add On
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79335
Printed Date: May 11, 2026 at 2:15 PM
Topic: 2000 impala ls Factory Add On
Posted By: flint-town
Subject: 2000 impala ls Factory Add On
Date Posted: June 19, 2006 at 4:41 PM
I have 2 Mtx 8000 and a RF 360a2
Everything is hooked up except the remote wire this is where i need help. There is the Factory Amp in the trunk is there any way to tap into the remot on that amp or am I going to have to get under the dash?
also isint there a inline converter that will give me a 12v signal from the speaker wire ?
Posted By: sparkie
Date Posted: June 19, 2006 at 6:13 PM
Check for a White wire in cavity A5 of the amps larger plug. This is your amp turn on wire. There is no such device to convert a speaker level signal into a switched 12 volt trigger.
sparky
Posted By: KarTuneMan
Date Posted: July 05, 2006 at 4:36 PM
Posted By: ryan2318
Date Posted: July 12, 2006 at 1:16 AM
just find the auxillary drop down in our cars.  This site wrote up a nice how to for it: https://www.impalahq.com/HowTo/Aux_Connector.html
I was going to explain it but they have pics and diagrams so much easier to just provide the link.
Posted By: sparkie
Date Posted: July 12, 2006 at 5:01 PM
Thanks Kar TuneMan. I never knew anything like that existed. I would still use the factory trigger, but if that unit works, its a pretty slick idea. I am not sure if some of the GM amps in the newer cars would like to see the load that the unit presents. They are pretty finicky,
sparky
